anyway to tell if ecu is obd2 or obd 1 by looking @ the outside
Old Jan 18, 2003 | 08:36 AM
tegrevboy's Avatar
Default anyway to tell if ecu is obd2 or obd 1 by looking @ the outside
I beginning to wonder what this ecu is all of the info i have found doesn't correspond w/ the wiring that is in the plugs that are in it right...now...
eithter that or no one that I have found with Ecu pinouts diagrams are right....
Old Jan 18, 2003 | 09:31 AM
jmm96gsr's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (tegrevboy)
well, first of all what ecu are u talking about? the plugs are different from obd1 and obd2. also, tell us what the numbers and letters are on the tag on the side of it.
Old Jan 18, 2003 | 09:36 AM
Soled Out's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (jmm96gsr)
OBD-1 ecu has 3 plugs
OBD-2 has 4 plugs i believe
Old Jan 18, 2003 | 09:40 AM
b16b hatch's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (Gray EG on Jack Stands)
here you go. http://www.hondata.com/techecuid.html
Old Jan 18, 2003 | 10:13 AM
b16 matt's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (b16b hatch)
I was going to say go to http://www.hondata.com but someone smote me to it. Damn
Old Jan 18, 2003 | 10:21 AM
google's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (b16matt)
ob2 4 plugs ob1 3 plugs
Old Jan 18, 2003 | 01:40 PM
Jonathan_ED3's Avatar
Default Re: anyway to tell if ecu is obd2 or obd 1 by looking @ the outside (1320in11)
Not true...I've got an OBDI 5 speed ECU w/ 4 plugs
supraccordlx
Mar 8, 2009 02:32 PM
civichbb18
Dec 15, 2004 04:50 PM
COMplex.
Mar 18, 2003 12:00 PM
