removing rear bumper
Old Jan 18, 2003 | 07:47 AM
rasta420's Avatar
Default removing rear bumper
i see the two screws under the rear quarter panels...do i have to take the taillights out for the other bolts? where are they?
thanks
Old Jan 18, 2003 | 07:55 AM
crxforum's Avatar
Default Re: removing rear bumper (rasta420)
Yup you do. Here is how you do it. Pop your hatch. Then look down. You will see the black plastic towards the back hatch wall. There are some peices that you can remove so you will be able to get at the taillights. Now get a 10mm socket and search for the screw that are holding the lights in place. Remove those. Now remove the bulbs by untwisting them from their sockets. Then pull the pail lights out. Now since those are out look down. You will see some screws on top of the bumper. Remove those. Then remove the ones in the rear wheel wells. Then get under the car and remove the screws that are holding on the bumper from the bottom. Dont forget the one under the exhaust tip.
CRX Forum
noobaccord
Apr 27, 2010 08:05 PM
Pnoyej6
May 23, 2006 04:00 PM
crooked muffler
Jul 9, 2003 07:18 AM
2001civicex
Aug 21, 2002 09:38 AM
civicracer1993
Mar 10, 2002 09:00 PM
