What kind of compression test numbers are you seeing with...
Old Jan 17, 2003 | 08:09 PM
sneakychaos's Avatar
Default What kind of compression test numbers are you seeing with...
B18C5, CTR pistons - std bore. Just curious to see what other people are getting compression test wise. This is also with a stock headgasket, but I'll take anyones numbers - just please include anything that may affect compression, IE porting combustion chamber, etc.
Thanks in advance.
Old Jan 18, 2003 | 12:15 AM
sgT's Avatar
sgT
Default Re: What kind of compression test numbers are you seeing with... (sneakychaos)
300+ generally with toda C cams.
cams will play into it but should be high 200s at least
Old Jan 18, 2003 | 01:48 AM
texan's Avatar
Default Re: What kind of compression test numbers are you seeing with... (sgT)
You sure about that? I've never even seen a compression gauge that goes past 300.
Old Jan 18, 2003 | 07:46 AM
bartek_b's Avatar
WTF???? 300+???
I thought they don't go past 250???
Old Jan 18, 2003 | 09:41 AM
Default Re: What kind of compression test numbers are you seeing with... (mugen85r)
WTF???? 300+???
Most gauges go upto 300, some go more. Just because the gauge stops at 300 doesnt mean the compression does.
negusjuda
Apr 3, 2013 02:33 PM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
ej1vtec
Jun 12, 2006 04:50 AM
pootie.teng
Jun 2, 2005 10:32 PM
