Is this common problem in EG6??
Old Jan 17, 2003 | 05:43 PM
ace1875's Avatar
Default Is this common problem in EG6??
Well I have a problem my Brake light is coming on for some unknown reason...
The Brake Fluid is up to level
The Brakes are fine
but the light comes on every now and then and goes away when i tap or wiggle my Hand brake
Is this common that you'll had to face?
How can i fix this plz?
Old Jan 17, 2003 | 05:45 PM
oldB18EF's Avatar
Default Re: Is this common problem in EG6?? (ace1875)
never had a problem with my brake light
[Modified by WR93EG, 9:45 PM 1/17/2003]
Old Jan 17, 2003 | 05:51 PM
tominos's Avatar
check your parking brake switch. you have a loose connection.
Old Jan 17, 2003 | 05:55 PM
ace1875's Avatar
Default Re: Is this common problem in EG6?? (tominos)
Can you tell me where thats locate plz
thanx
B18C5-EH2's Avatar
Former Moderator
Loved
I don't think there is anyone here who even owns an EG6.
Old Jan 17, 2003 | 05:58 PM
ace1875's Avatar
Default Re: Is this common problem in EG6?? (B18C5-EH2)
well i ment EH
Old Jan 17, 2003 | 06:03 PM
ill phil's Avatar
Yeah if you are referring to your parking brake light, there should be a butt connector with a wire or two connected onto the E-brake itself. That may be loose as someone has said. If you pull off your e-brake cover you will see the wire that is attached.
Old Jan 17, 2003 | 06:19 PM
ace1875's Avatar
Default Re: Is this common problem in EG6?? (ill phil)
will try it thanx
Old Jan 17, 2003 | 06:23 PM
Nocturnal's Avatar
If your brake light comes on doesn't it mean something is wrong with your altenator? That's how it was with my car. I'm not too sure though.
Old Jan 17, 2003 | 06:26 PM
ace1875's Avatar
Default Re: Is this common problem in EG6?? (psychotic)
im sure its not the alternator cause when i mess with the Hand Brake the Thing goes away like if i press the Hand Brake button
Old Jan 17, 2003 | 06:27 PM
CHRIS 1.8's Avatar
Old Jan 17, 2003 | 06:37 PM
Slurp56's Avatar
Not true.
Not true, that'd be your battery light.
This is where my money is. remove the plastic housing over your hand brake. There is 1 wire towards the base and a little plastic spring loaded plunger style switch. Make sure its not worn and make sure the connection is good.
Old Jan 17, 2003 | 06:55 PM
The Destroyer's Avatar
Default Re: Is this common problem in EG6?? (Slurp56)
Slurp you own an eg6?
GeoMetry
Aug 25, 2024 03:41 AM
btman
Oct 12, 2007 06:11 AM
tennbidder
Acura TL, RL & ZDX
Jun 9, 2007 06:27 PM
low430
Oct 30, 2005 01:02 AM
civicboisi
Mar 8, 2003 06:45 AM
