B-Series Cam Spec List (Specs all @1mm)
Old Jan 17, 2003 | 01:21 PM
Mr.Saturn's Avatar
Default B-Series Cam Spec List (Specs all @1mm)
Recently I was looking for a good cam set for the application I am currently looking for and found a number of different lists for cam specs. The Japanese standard for measuring cam specs is @1mm which is, unfortunately, different from what some American brands like to measure at. I went through all the specs I had and converted them all to @1mm (except 3 I haven't done yet). This lets you do a much more accurate side-by-side comparison. I know there are a few other brands available (ZEX is one I just didn't put in, although I did know about it). If anyone knows any specs for sure that I have not included, please post and I will update the list!
<U>ALL</U> listed at @ 1mm!
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Integra Type-R Pre '99 Spec
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R
Int-243 dur. / 11.5mm lift
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
Toda Spec A
Int-250 dur. / 11.6mm lift
Exh-240 dur. / 11.2mm lift
Toda Spec B
Int-255 dur. / 12.0mm lift
Exh-245 dur. / 12.0mm lift
Toda Spec C
Int-255 dur. / 12.5mm lift
Exh-255 dur. / 12.5mm lift
Toda Spec D (Estimated)
Int-265 dur. / 12.9mm lift
Exh-275 dur. / 11.9mm lift
Toda VTEC Killer
Int-265 dur. / 12.0mm lift
Exh-255 dur. / 11.5mm lift
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
JUN Type 2
Int-267 dur. / 12.0mm lift
Exh-265 dur. / 10.9mm lift
JUN Type 3
Exh-265 dur. / 11.5mm lift
Skunk2 Stage 1
Int-252 dur. / 11.6mm lift
Exh-249 dur. / 10.8mm lift
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
Skunk2 Turbo (specs seem low? I called them, the VTEC now has less overlap, great for turbo )
Int-230 dur. / 9.7mm lift
Exh-225 dur. / 8.9mm lift
Crane Stage 1
Int-243 dur. / 11.6mm lift
Exh-237 dur. / 10.8mm lift
Crane Stage 2
Int-248 dur. / 12.0mm lift
Exh-242 dur. / 11.6mm lift
Crane Stage 3
Int-254 dur. / 12.4mm lift
Exh-248 dur. / 12.0mm lift
Crower 400 (not converted yet)
Int- dur. / 10.7mm lift
Exh- dur. / 9.6mm lift
Crower 401 (not converted yet)
Int- dur. / 11.3mm lift
Exh- dur. / 10.5mm lift
Crower 401T (not converted yet)
Int- dur. / 11.8mm lift
Exh- dur. / 11.3mm lift
Crower 402A
Int-232 dur. / 11.8mm lift
Exh-228 dur. / 11.8mm lift
Crower 402
Int-237 dur. / 11.8mm lift
Crower 403
Int-246 dur. / 12.0mm lift
Exh-238 dur. / 11.8mm lift
Crower 411T
Int-242 dur. / 11.8mm lift
Exh-238 dur. / 11.3mm lift
Crower 412
Int-260 dur. / 11.8mm lift
Exh-252 dur. / 11.8mm lift
Crower 413
Int-269 dur. / 12.0mm lift
Exh-258 dur. / 11.8mm lift
Enjoy!
Old Jan 17, 2003 | 02:55 PM
10K2HVN's Avatar
Default Re: B-Series Cam Spec List (Mr.Saturn)
gotta save this! thanks..!
Old Jan 18, 2003 | 01:54 AM
Mr.Saturn's Avatar
ttt just in case anyone else would like to see
Old Jan 19, 2003 | 06:29 PM
10K2HVN's Avatar
yeah i agree with you...
Old Jan 19, 2003 | 10:32 PM
SergEK's Avatar
Default Re: B-Series Cam Spec List (10K2HVN)
Bump Good info for cam comparison
Old Jan 19, 2003 | 10:41 PM
texan's Avatar
Default Re: B-Series Cam Spec List (SergEK)
1 question: how did you convert .05" lift and duration specs to 1mm (.0394") lift and duration specs? As far as I know, there's no way to reliably do this.
Old Jan 20, 2003 | 12:34 AM
If You Slip You Die's Avatar
Old Jan 20, 2003 | 12:55 PM
Mr.Saturn's Avatar
Not so much convert as do all the dirty work calling various companies. These are all confirmed, the 3 that are not listed were not, and I didn't wanna post (possibly) inaccurate info. Enjoy!
Old Jan 24, 2003 | 02:14 PM
Mr.Saturn's Avatar
one last bump to the top unless anyone else wants to
Old Jan 24, 2003 | 05:50 PM
earl's Avatar
Cool list, thanks
Old Jan 24, 2003 | 06:08 PM
976's Avatar
976
New User
Old Jan 20, 2004 | 05:41 PM
80884's Avatar
nice list!
interesting to me to see that the gsr and 99-00 si exhaust cams are the same, learned something new
Integra GS-R
Civic Si '99 Spec
Old Jan 20, 2004 | 06:59 PM
DA-nteg's Avatar
Default Re: B-Series Cam Spec List (80884)
does anyone know if specs are different for first gen b16 cams
tia
IN VTEC's Avatar
I've been trying to get all the open and closing angles at .050" as well as the lobe centerline angles. I'll try to put up what I have some time later on, but some are pretty hard to come by.
Old Mar 29, 2005 | 09:11 PM
slayersluck's Avatar
bump good info
Old Apr 3, 2005 | 07:34 PM
BrownGSR's Avatar
Default Re: B-Series Cam Spec List (slayersluck)
nice info, but what are the crower 401 specs?
Old Apr 3, 2005 | 09:47 PM
TrackSpeedRacing's Avatar
Default Re: B-Series Cam Spec List (BrownGSR)
Crower 401
Int- 249 @ 1mm dur. / 11.38mm lift
Exh-240 @ 1mm dur. / 10.54mm lift
Crower 401T
Int- 240 @ 1mm dur. / 11.81mm lift
Exh-237@ 1mm dur. / 11.30mm lift
Old Apr 4, 2005 | 07:53 AM
X2BOARD's Avatar
By chance, did you come across automatic SiR cams ? Alot of ppl are looking to find out the measurements as comparted to the manual ones.
Old Apr 4, 2005 | 08:21 AM
suckawillis's Avatar
Default Re: (X2BOARD)
so thee 99 si cam is better than a gsr cam? you sure?
Old Apr 4, 2005 | 10:05 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (suckawillis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suckawillis &raquo;</TD></TR><TR><TD CLASS="quote">so thee 99 si cam is better than a gsr cam? you sure?</TD></TR></TABLE>
Nope...
Old Apr 4, 2005 | 10:27 AM
X2BOARD's Avatar
I'm sure this is all on the VTEC lobe... anyone know if the stock cams differ in primary lobe size ?
Old Apr 7, 2005 | 09:40 AM
Default Re: (LSVTEC 91 Civic)
but this post shows the 99 si cam to haver higher lift and duration than a gsr. i think the #s are wrong on that
Old Apr 14, 2005 | 06:18 AM
CrisEK's Avatar
does anyone know if there's any difference between 1st & 2nd gen. B16 cams. I have a B16A3, but my friend is givin me some 99" B16A2 cams. Just wondering if it's worth my time to swap em over.
Old Apr 18, 2005 | 10:25 PM
YellowCTR's Avatar
Default Re: (PangaEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 &raquo;</TD></TR><TR><TD CLASS="quote">nice list!
Integra GS-R
Civic Si '99 Spec
Does anyone know the if those numbers are correct??? Seems intresting if soo....
Old Apr 18, 2005 | 10:49 PM
2k.civic.si's Avatar
Default Re: (TurboEJ6)
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
measured with 0mm of lift
ya numbers are wrong....even converted to 1mm of lift the gsr cams have more duration and more lift on the intake side
