Help with tires
Old Jan 17, 2003 | 10:35 AM
thickfacek's Avatar
Default Help with tires
I have a 94 accord ex, lowered bout 2.5 inches. Im currently running 205/40 on 17 inch rims. I wanna move up one step to 205/45 due to the poor quality roads around here. I'm sure i have plenty of room under the fenders for one size up but my question is, do you guys think going from a 40 to 45 will make that much of a difference as far as saving the rims from pot holes?? And also let me know what yall are running on your accords. Pics would be nice too. Thanks...
Old Jan 17, 2003 | 11:27 AM
jingjing's Avatar
Default Re: Help with tires (thickfacek)
i think 215/45/17 is the correct size you need.
Old Jan 17, 2003 | 11:42 AM
TheOnlyChrisB's Avatar
Default Re: Help with tires (jingjing)
In order to stay at stock height/size of tires, jingjing is correct.
Old Jan 17, 2003 | 12:23 PM
jingjing's Avatar
Default Re: Help with tires (TheOnlyChrisB)
thank ya, thank ya very much
Old Jan 17, 2003 | 09:26 PM
Bantam's Avatar
2nd Coolest Person in DFW
I live in a place with some shitty roads and i have 215/45/17 on my wheels, they really work well
Old Jan 18, 2003 | 01:20 AM
ChrisLe182's Avatar
Default Re: Help with tires (tharptroy)
I believe 205/45-17 is a better size... Because if stock size is 195/60-15, it gives you a 76.07 inch circumference. 205/45-17 tires would give you 76.23, which is closer than a circumference of 77.34 of the aforementioned 215/45-17 tires.
-Chris
Old Jan 18, 2003 | 02:58 PM
honda4drtnr's Avatar
Default Re: Help with tires (ChrisLe182)
What would you guys use with 18''?
Old Jan 18, 2003 | 04:46 PM
Bantam's Avatar
I didnt think that width changed circumference, How does that work?
Old Jan 18, 2003 | 05:00 PM
93acclude's Avatar
The height number is actually an aspect ratio between the width and the height. It does not translate to a specific measurement across the range of tire sizes like the width does... i.e. a 215 tire is the same width wether it is a 40 series or a 55 series. It is still 215mm across. The actual height changes in a series depending on the width.
DarkTeg94
Mar 7, 2006 07:59 AM
unknown0001
May 17, 2004 05:27 PM
crznlo
Aug 28, 2003 11:25 AM
gavhowe
Sep 27, 2002 08:23 AM
SoSoJeff
Jan 15, 2002 05:57 PM
