Really confused about this.
Old Jan 17, 2003 | 06:56 AM
Krnbk2's Avatar
Default Really confused about this.
Ok here is my problem.
In the next few months i plan on going with an itr 4 lug conversion for my 96 dx hatchback. its a direct bolt up which is great but im starting to get concerned with what wheels will fit.
I know my car now has 4 x 100 bolt pattern with a +40mm offset
I also know that the 96 ITR oem rims are: 15x6.5 +45mm offset and 4x114.3 bolt pattern.
To my knowledge on offsets, the lower (numerically) the number is for the offset the further out the wheel is pushed to the fender and the higher the number the further in the wheel is pushed to the shocks/struts.
I can find 4 x 114.3 bolt pattern rims pretty easily but im having a hard time finding them with 45mm offsets.
I guess my question is, Will i be able to run a 40mm offset rim with the new suspension without rubbing? or am i stuck buying the ITR wheels and just dealing?
Thank you in advance
Old Jan 17, 2003 | 06:59 AM
Doctor CorteZ's Avatar
Default Re: Really confused about this. (krnbk2)
why not just do a gs-r brake swap ?
keep the same pattern and the brakes are 10.3"
Old Jan 17, 2003 | 07:00 AM
Krnbk2's Avatar
Default Re: Really confused about this. (Doctor CorteZ)
I knew someone was going to say that.
because im getting a good deal on the itr swap.
Old Jan 17, 2003 | 08:19 AM
Krnbk2's Avatar
no one knows anything? has had any expierence
Old Jan 17, 2003 | 08:36 AM
lsvtecracer's Avatar
I thought the itr was a 5 lug conversion....The lug patterns would actually be
5 X 114.3
Old Jan 17, 2003 | 08:49 AM
Patrick's Avatar
Default Re: Really confused about this. (lsvtecracer)
The ITR didnt get 5 lug till 1998, this is from a 96.
Old Jan 17, 2003 | 08:52 AM
spoon_ek9's Avatar
it will be same as your stock wheel. FYI, all honda stock wheel is 45 offset.
[Modified by spoon_ek9, 5:53 PM 1/17/2003]
Old Jan 17, 2003 | 09:40 AM
I didnt know gs-r brakes were expensive...
oh well , do what you want.
Old Jan 17, 2003 | 10:14 AM
b16 matt's Avatar
ITR's are 5 lug.
Old Jan 17, 2003 | 10:15 AM
b16 matt's Avatar
Default Re: Really confused about this. (ethug4life)
sorry I didnt read on. true after 96 it was 5. do the gsr.
Old Jan 17, 2003 | 10:16 AM
Patrick's Avatar
ITR's are 5 lug.
Not all itr's, earlier years had 4 lugs, learn it love it and for christ sake remeber it!
Old Jan 17, 2003 | 10:17 AM
Patrick's Avatar
Default Re: Really confused about this. (gsr_vx_hatch)
Woops, oh well.
Old Jan 17, 2003 | 10:18 AM
Evs-One's Avatar
Solbros Owns Me
96 Type R's had 4 lug, 97 on up had 5
kozanatos
May 20, 2011 04:53 AM
Sivic90
Sep 23, 2008 04:45 PM
Kgb
Nov 10, 2005 03:22 PM
theeogflip
Sep 21, 2005 06:44 PM
BlackOut21
Mar 22, 2003 11:23 PM
