Suspension Techniques Front Sway Bar?
Old Jan 17, 2003 | 06:31 AM
Casual Gcode1's Avatar
Default Suspension Techniques Front Sway Bar?
I got a Suspension Techniques Sway bar set...I put the rear bar on but have heard that I dont need the front one. Has anyone rode with it on and off? Which rides and handles better. Is it worth putting on or should I try and sell it?
Old Jan 17, 2003 | 07:08 AM
misledyouth's Avatar
New User
Default Re: Suspension Techniques Front Sway Bar? (Casual Gcode1)
io had a 26mm si front bar and the suspension techniques 19mm rear
i ended up taking off the front cause it pushed to much. depending on what size it is i would put it on to neutral out the handling.
jesse
Old Jan 17, 2003 | 09:25 AM
Default Re: Suspension Techniques Front Sway Bar? (misledyouth)
Both the front and the rear are 25mm...So what do you think I should do? Test it out both ways? Anything helps.
Old Jan 17, 2003 | 10:48 AM
Tweakmeister's Avatar
I wouldn't bother with the front one because of the increased tendency to understeer.
generally, a smaller front is better, but more "dangerous"
Old Jan 17, 2003 | 11:07 AM
Default Re: Suspension Techniques Front Sway Bar? (Tweakmeister)
generally, a smaller front is better, but more "dangerous"[/QUOTE]
"dangerous" meaning?
Old Jan 17, 2003 | 11:18 AM
sgT's Avatar
sgT
i would use them both on the prelude
Old Jan 17, 2003 | 11:44 AM
Default Re: Suspension Techniques Front Sway Bar? (sgT)
Any specific reason why?
Old Jan 17, 2003 | 12:36 PM
10K2HVN's Avatar
But his rear swaybar is HUGE!!! 25 and 25...the 25 in ther rear sould cancel out the increase in the front and just keep it all even..or oversteer (well more then stock.)
H22A4Me
Feb 22, 2006 05:23 PM
vinuneuro
Suspension & Brakes
Feb 10, 2006 06:38 PM
