I know shes on here now . maybe she can answer, but whats Jens set up in the Teg
Old Jan 17, 2003 | 05:02 AM
PM-Performance's Avatar
Default I know shes on here now . maybe she can answer, but whats Jens set up in the Teg
I was just curious becuase in superstreet or turbo or wherever they say its a stock b16 with turbo on it ? Im curious as to what is all done to it and the maount of boost she pushes on that thing and its best times?
also is it trailored or not ?
Any hp numbers.
I never erally got a chace to take a look at it since she brought it back.
Old Jan 17, 2003 | 05:25 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (itr206)
I think Jason posted about her set up in fi. Might want to dig up some of his old post.
art
Old Jan 17, 2003 | 05:36 AM
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (Arturbo)
thanks , ill see if i can find it .
Old Jan 17, 2003 | 06:40 AM
littlebluecrx's Avatar
If you cant find it , I can give you some info, I hate typing. but her car was a second gen teg, not the third gen she drove for myles at palmdale.let me know Jason
Old Jan 17, 2003 | 06:52 AM
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (littlebluecrx)
i know she got the seoncd gen , black . i thinki remember her driving it back in the day . and thne went with inline . and then whatever happened , she ended up back in her 2nd gen again . . . if im correct.
i havent found it yet, i just tried searching under her name
[Modified by itr206, 7:54 AM 1/17/2003]
Old Jan 17, 2003 | 12:49 PM
RACERetteX's Avatar
hellooo. here's the scoop. the black 92 integra is owned by kim hemphill and chad britton. kim used to drive it and her blue GSR back in the day. after the split with inline i was still in the points and they offered it to me to finish up the season. we put a B16 that was in charlie's all motor car in it real quick until we could build something and that's what was in the car in the first turbo spread from atco. turbo'd and 50 wet shot of NOS. and we couldn't blow it up....we tried! that setup ran a 10.3, not pushing too much boost-if i remember right MAYBE it hit 15lbs. we were kinda trying to be conservative with it. keep in mind this was with wheeliebars, but otherwise the car weighed in at a hefty 2300lbs+ with full glass, etc. after that we did a built 1.8, never saw more than like 22lbs boost if i remember right still spraying the 50 shot. best e.t. was against jojo callos at etown with a 10.0. had we more time and/or resources it would have run 9's, no doubt about it. we were also limited in that the owners wanted the car back the way they gave it to us, so we kinda had our hands tied there so far as trying to save some weight.
but that's the story. myles' integra you're gonna have to ask him about...that was a whirlwind weekend and i couldn't even have begun to process all that info on top of trying to get it down the track. i'll bet it's got a revhard manifold and turbo setup on it though.
-jen.
oh yeah...the car is actually for sale if anyone's interested www.isuzustyle.com/integraFS.html
[Modified by RACERetteX, 9:50 PM 1/17/2003]
[Modified by RACERetteX, 9:52 PM 1/17/2003]
[Modified by RACERetteX, 10:02 PM 1/17/2003]
Old Jan 18, 2003 | 04:31 AM
Drag_Dc2's Avatar
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (RACERetteX)
10.3 is an amazing accomplishment on a stock block!! What do you believe was the major factor in allowing such astonishing times? Was it the Speed Pro system? Also if I recall i correctly I beleive Jason stated you were pushing 20lbs of boost in a previous post? Also what type of turbo and manifold were you running?
Old Jan 18, 2003 | 06:48 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (DragDc2)
Wasnt this run at Rockingham if im not mistaken? If so i saw some video on it and i gotta saw WOW!
Old Jan 18, 2003 | 08:41 AM
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (LUNSPEED 1)
so that was all on stock block ? damn ,thats what i want to hear.
i want to see if i can get into quick class this year with my car, it still needs work , but i wanted to see how that one was holding up with that motor and amount of boost.
thanks.
Old Jan 18, 2003 | 08:46 AM
the car had a stock b16 bottom end jdm baybee!, but we slapped to stock headgskets on with heavy duty factory b16 studs holding it together, we then crossed are fingers torqueing the head down too around 68 foot pounds.The head was port flow gsr head meant for all motor. The car would not boost over 17 pounds, in lower gears it would not see over 15, when we put the bottle on the data log showed around 20 pounds. Jen was right about the boost level, the nitrous added a few extra psi.. We ran those time with a bastard clutch set up, a rps pressure plate, and a clutch masters stage 5 disc" I ran it all the year before in my crx". we then built the motor, made a hell of a lot more power, and ran 10.0? Make me no longer believe in dyno's, but with more power the chasie needed help, so it was harder to get it to the ground with out wheel hop. We are the most proud of the little b16 setup, cause we had no clue it would ball the way it did. Sorry for the ramblings. Jason
Old Jan 18, 2003 | 10:40 AM
Drag_Dc2's Avatar
Jason,
Do you believe the Speed Pro made the biggest difference? Or do you think you could have accomplished similar results off a stock ECU???
Old Jan 18, 2003 | 11:32 AM
paulzy's Avatar
very impressive
Old Jan 18, 2003 | 12:04 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
We had no clue it would ball the way it did.
And BALL it did, suprised the $hit out of me, i remember the first event it ran at, i was stupified
Old Jan 18, 2003 | 01:04 PM
here2race-no.b.s's Avatar
Was it the Speed Pro system? Also what type of turbo and manifold were you running?
Hi this is Charlie, Speed pro is nice because you can really fine tune your settings via timing and fuel. Plus really get a feel for what it is doing on the track. Manifold was a cast Rev Hard manifold. Turbo was a trubonetics unit that was on loan from Jamie (with the red sentra) we don't even know exactly what it's specs are.
Old Jan 18, 2003 | 02:50 PM
Pelican's Avatar
Default Re: I know shes on here now . maybe she can answer, but whats Jens set up in the Teg (here2race-***.
Man, I love to hear that type of stuff. A few MAGIC motors doing so well. Very inspiring. Go
Old Jan 18, 2003 | 06:55 PM
AR Fab's Avatar
Hey Charlie and Jen!! Glad to see you guys up on the board....
BTW Jason Lopes was up all week, he meant to contact you guys and invite you to the shop to hang out. We were so busy working on his car though we never got the time to call during a decent hour.....
Anyways he said for me to tell you guys hi.....LOL....Charlie did Jason tell you what was wrong with the FAST systems....what a joke! Glad we have that behind us now......
Howard
[Modified by AR Fab, 10:57 PM 1/18/2003]
[Modified by AR Fab, 10:58 PM 1/18/2003]
[Modified by AR Fab, 10:59 PM 1/18/2003]
red_DA_wonder
Feb 20, 2003 07:08 PM
Aphrodavid
Jul 28, 2002 10:29 AM
