installed my intercooler and now car barely runs
Old Jan 16, 2003 | 10:09 PM
wrXtian's Avatar
Default installed my intercooler and now car barely runs
ok.. i spent a lot of today installing my intercooler in my car.. i finally finished everything and put it all back together.. when i started my car it was ideling at like 400-500 rpm and sputtered like it was barely running.. the last time it ran like that was when my msd coil had a crack in the cap. the only thing i can think of is maybe a charge pipe clamp is loose and that's keeping it from running right. my car is only getting 5 psi now when it was getting 6 before the intercooler, but the end tanks of the intercooler are a lot smaller than the charge pipes so i thot that could be restricting some of the boost. my bov doesn't really seem to go off like it did before.. now i hear the wastegate a lot more.. i'm just not really sure what's going on with it.. can anyone help me.
thanks
Old Jan 16, 2003 | 10:13 PM
Flamenco-T's Avatar
Default Re: installed my intercooler and now car barely runs (xjdm94x)
you sure, you're not leaking boost ?
Old Jan 16, 2003 | 10:20 PM
wrXtian's Avatar
Default Re: installed my intercooler and now car barely runs (Flamenco-T)
i was thinking that but i wasn't sure if that would be the reason why the idle would be bad.
Old Jan 16, 2003 | 10:25 PM
UberTeg's Avatar
[quote]my car is only getting 5 psi now when it was getting 6 before the intercooler[/quoe]
The temperature drop is direcly related to the pressure drop. That just means your intercooler is doing its job unless you're using a vacuum source after the ic for your wastegate
Old Jan 16, 2003 | 10:31 PM
wrXtian's Avatar
Default Re: installed my intercooler and now car barely runs (UberTeg)
could it be my charge pipes are too big? they're only 2 inches tho.. but there is a lot of piping.. maybe the piping is too long and it's starving the engine of air?? ahhh i duno damn this home made turbo crap i shoulda just bought a drag gen 2 for the gen 2 teg..
Old Jan 16, 2003 | 10:38 PM
Flamenco-T's Avatar
and you checked for vac leak ? piping should not made a difference, unless they're 50 feet from the turbo to the TB
Old Jan 16, 2003 | 10:45 PM
wrXtian's Avatar
i'll look at it some more 2m morning check my map sensor hose and stuff like that.. i checked some of the connectors for the pipe and those seemed tight and everything.
Old Jan 16, 2003 | 11:27 PM
KingDsi's Avatar
I think UberTeg is right. It is normal to see a pressure drop (minimal) with an intercooler. You might just have to re tune it a little. Make sure your connected right on your vacuum/boost lines.
Old Jan 17, 2003 | 03:47 PM
wrXtian's Avatar
hmm.. ok i'm a complete dumb ***.. my map sensor hose had a big kink in it so no air was flowing to the map sensor
but the car still seems a little funny.. i'm not sure to the feel of this intercooler
b20beast83
Feb 26, 2010 10:02 AM
tyrone27
Jul 30, 2004 11:29 AM
91glassycrx
May 7, 2004 12:26 PM
syeve
Jul 8, 2002 03:23 PM
Arturbo
Nov 17, 2001 05:15 AM
