Raised wrist pins/Longer rods worth it? Downside?
Old Jan 16, 2003 | 09:19 PM
TimoneX's Avatar
New User
Default Raised wrist pins/Longer rods worth it? Downside?
I've searched exhaustively, and haven't found much info on this topic. I'm getting new pistons and I'm considering the raised wrist pin/longer eagle rod combo. Has anyone tried this combo for any length of time? My math indicates a mere .04 increase in R/S ratio from 1.581 to 1.622, but the cost is not much higher either. I did see one person claim that the raised pin pistons suffered from a weaker structure around the ring lands. Anyone have any input?
Old Jan 17, 2003 | 12:09 AM
BluntMan's Avatar
Default Re: Raised wrist pins/Longer rods worth it? Downside? (TimoneX)
any better r/s ratio, is good. id go for it!
Old Jan 17, 2003 | 02:17 AM
texan's Avatar
Default Re: Raised wrist pins/Longer rods worth it? Downside? (BluntMan)
If the wrist pin location bisects the oil control ringland support, don't bother. The drop in sealing capacity is generally regaded as a race possible, street stupid design. Beyond that, it makes a lot more sense to offset the piston pin than just to move it up, as that will make a bigger and more positive difference in rod angularity (and hence dwell times) than pin upward movement.
Old Jan 17, 2003 | 02:29 AM
TimoneX's Avatar
New User
Default Re: Raised wrist pins/Longer rods worth it? Downside? (texan)
Well stated as always.
kpjo4
Mar 11, 2010 07:56 PM
redsolturbo
Aug 7, 2008 02:36 PM
bluedlude
Dec 15, 2007 09:26 AM
forcedaccord95
Apr 30, 2005 10:07 PM
boost fed ls
Jan 29, 2005 04:20 AM
