oversize vavles w/ upgraded cams = bad
Old Jan 16, 2003 | 09:00 PM
98civicEX's Avatar
Default oversize vavles w/ upgraded cams = bad
was doing some surfing on the net and read on the skunk2 site that oversized valves should not be used w/ their stage 2 or higher cams. was trying to think of a logical reason for this...but obviously can't....can someone explain why?
Old Jan 16, 2003 | 09:39 PM
earl's Avatar
Default Re: oversize vavles w/ upgraded cams = bad (98civicEX)
The combination of greater lift of both valves combined with the larger valve diameter could cause the the intake to hit the corresponding exhaust valve in the overlap cycle. Never seen it happen but I guess it is possible in an extreme case.
Old Jan 16, 2003 | 10:00 PM
lazerus's Avatar
Default Re: oversize vavles w/ upgraded cams = bad (earl)
i'd tell you why but then i'd get in a flame war i'm sure.... post your e-mail addy and i'll tell ya.
adim
Jul 17, 2009 08:24 PM
revhardallday
Nov 26, 2008 03:08 PM
ohsnapzafingcu
May 31, 2007 06:58 PM
matata55
Dec 23, 2004 09:54 PM
THCk20eg
May 23, 2004 10:13 PM
