Driver's seat is squeeking.
Old Jan 16, 2003 | 08:54 PM
STC's Avatar
STC
Default Driver's seat is squeeking.
My driver's seat is squeaking. I didnt think it had nothing to do w/ the raild, but I WD-40'd it anyways and its still squeeking. It only squeeks when I launch from first.
Any suggestions??
Old Jan 16, 2003 | 08:56 PM
98itR484's Avatar
Default Re: Driver's seat is squeeking. (STC)
did you try the bolts??? Check to see if all the springs are still intact.
B2FiNiTY's Avatar
It could be broken. A few ITR owners have experienced this.
Old Jan 16, 2003 | 09:03 PM
STC's Avatar
STC
Default Re: Driver's seat is squeeking. (B2FiNiTY)
broken? warrenty should cover this?
i have a 00 w 25k miles on it.
Old Jan 16, 2003 | 11:21 PM
STC's Avatar
STC
Who else has experienced this??
Did Acura just replace the seat?
Old Jan 16, 2003 | 11:22 PM
B2FiNiTY's Avatar
Depends on the dealer but they "should" replace it.
ILLTEGRA
Guest
Posts: n/a
i have squeeking, when i ever i drive over a bump.
Old Jan 16, 2003 | 11:32 PM
ingrate's Avatar
25 Year Member
Default Re: Driver's seat is squeeking. (ILLTEGRA)
it's probably your seat belt clip. use silicone spray in that area.
Old Jan 16, 2003 | 11:36 PM
Type-Rare#1248's Avatar
Default Re: Driver's seat is squeeking. (In7egrity)
i have a squeeking problem with my seat too...is this a problem many ITRs have
Old Jan 17, 2003 | 03:13 AM
typer.org's Avatar
make sure it is the seat. When I drive I hear a squeaking which I thought was the seat, but it is actually the seat belt. Where the belt goes down to the seat that joint squeakes.....
Old Jan 17, 2003 | 03:38 AM
benmasters's Avatar
Default Re: Driver's seat is squeeking. (typer.org)
My Recaro developed a squeak over xmas but it has dissapeared this last week. It came from seat for sure, just where the small of your back is. it was like a dry metal to metal squeek - it was *$"£$"£$* annoying.
Old Jan 17, 2003 | 04:02 AM
jond's Avatar
Default Re: Driver's seat is squeeking. (benmasters)
Mine too. For mine, its the seatbelt thing thats to your right side thats rubbing or something. If you hold it when you go over bumps, the sqeak goes away.
Old Jan 17, 2003 | 04:04 AM
itr1244's Avatar
Default Re: Driver's seat is squeeking. (jond)
Mine does it too.
Old Jan 17, 2003 | 04:11 AM
arren123's Avatar
I thought it was coming from the middle of the seat wear your buttcrack is.
I'll have to check mine out on my drive home today
Old Jan 17, 2003 | 05:29 AM
Larkin W.'s Avatar
Default Re: Driver's seat is squeeking. (arren123)
Its the seatbelt! At least that what it is on mine. I thought it was the seat when I first got my ITR but figured out that its the seatbelt
Old Jan 17, 2003 | 05:56 AM
pyromaster's Avatar
I thought it was coming from the middle of the seat wear your buttcrack is. I'll have to check mine out on my drive home today
that's where it sounds like on mine too.
Old Jan 17, 2003 | 06:25 AM
TypeR714's Avatar
Default Re: Driver's seat is squeeking. (EbboyPSi)
Yup, mine does the same thing. Annoys me. Anyone have problems with the seatbelt not clicking in all the way and popping out when your driving? Mine does that and I always push it in all the way till it clicks.
Old Jan 17, 2003 | 06:33 AM
goern-R's Avatar
Default Re: Driver's seat is squeeking. (TypeR714)
My passenger side belt does this. Acura has the part, and it's getting installed on Monday (under warrenty)
Old Jan 17, 2003 | 09:11 AM
STC's Avatar
STC
Default Re: Driver's seat is squeeking. (goern-R)
thanks guys, i'll check the seat belt when i go home tonight!
Old Jan 17, 2003 | 09:46 AM
TypeR 01 886's Avatar
I dont think that Acura will do anything about a "Squeak" but, I know if you take like one of the "red" threads that hold the fabric together on your seat (THE UNWORN SIDE) in most cases the right side of driver seat and jut cut one of them, and let it unravel... that would be a defect and they would have to reaplce it under warranty.
Now if you read the manual for the warranty, it says that they do not cover "squeaks or cricks"
Old Jan 17, 2003 | 11:30 AM
Champ R's Avatar
Default Re: Driver's seat is squeeking. (skafia++)
My seat does the same thing, especially when you lean forward in it. Also does any of your guys passenger sun visor make noise or vibrate when driving? Its most apparent on the highway if you have the radio off.
jdmdb8r
Apr 22, 2010 12:25 PM
butter99
Dec 28, 2009 08:02 PM
bmcp.
Sep 28, 2009 09:37 PM
dogmelissa
33
Dec 11, 2007 04:34 AM
acuraLSSE95
Mar 25, 2002 07:15 AM
