zc clutch spec with lsd
ok, so i just bought my zc motor and tranny combo (lsd tranny) for $700 to replace my blown zc. im going with a stock clutch due to lack of funds, but which clutch do i need? i know that the clutches are year dependent, and my zc is an 89. i counted the splines on the tranny shaft that the clutch goes into, and it's 20 splines. is this sufficient info in ordering a clutch? which clutch do i need? i obviously want to go with the best stock option, but am trying to stay in the $100 range.
any help as to which clutch i need and/or which clutch would be the best solution would be greatly appretiated
thanks
thanks
88 has a 21 spline input shaft, the 89-91's have a 20 spline shaft
So you need a 89 clutch
Also if you can find a 1990 Flywheel you can get a 90 or 91 clutch which is larger 212mm
[Modified by reXem, 8:19 AM 1/18/2003]
