U.S. Type R vs JAP Type R
Old Jan 16, 2003 | 07:06 PM
JOMO
Guest
Posts: n/a
Default U.S. Type R vs JDM Type R
i live in jamaia, we have mostly japanese type r's here, 4 lug, well one guy has a 5 lug, im assuming its usa, and he gets his *** kicked all the time
are the american type r's 'watered down' if so...how?
[Modified by JOMO, 6:55 AM 1/18/2003]
Old Jan 16, 2003 | 07:08 PM
B2FiNiTY's Avatar
Default Re: U.S. Type R vs JAP Type R (JOMO)
Not watered down by much compared to the 96 spec.
Old Jan 16, 2003 | 07:13 PM
JOMO
Guest
Posts: n/a
Default Re: U.S. Type R vs JAP Type R (B2FiNiTY)
so....they arent slower by much, not sure what you mean by 96 spec?
Old Jan 16, 2003 | 07:14 PM
Mr Boston's Avatar
JDM ITRs has higher compression and comes with the OEM JDM 4-1 header, and I think a different exhaust system compared to the USDM ITRs
[Modified by Integra Type R, 11:14 PM 1/16/2003]
skafia's Avatar
25 Year Member
In Japan, they have 96Spec, 98Spec, and 00Spec Type R's.
Old Jan 16, 2003 | 07:17 PM
B2FiNiTY's Avatar
Default Re: U.S. Type R vs JAP Type R (skafia)
The 96 spec has close to the same header as the USDM, I believe the bottom peice is different.
I bet he just can't drive.
Old Jan 16, 2003 | 07:22 PM
skafia's Avatar
25 Year Member
96Spec also had a weaker brake setup and suspension.
Old Jan 16, 2003 | 07:32 PM
itr1235's Avatar
is there both left and right hand drive
Old Jan 16, 2003 | 07:34 PM
Hooch'n's Avatar
96 spec had 4lug, smaller brakes, Different header, Lights, ex.
98 spec had 5 lug, larger brakes, 4-1 header, different gear ratio....
But ran similar or same 1/4 mile times, big difference is the braking power!
Info: BMI, Options Videos
Old Jan 16, 2003 | 07:42 PM
biassj's Avatar
Default Re: U.S. Type R vs JAP Type R (Hooch at 8400-RPM)
I think the 98 and up weigh only 2380.
Old Jan 16, 2003 | 07:43 PM
skafia's Avatar
25 Year Member
Default Re: U.S. Type R vs JAP Type R (biassj)
That's if you got it with No A/C, ABS, Stereo, etc...
Old Jan 16, 2003 | 07:45 PM
skafia's Avatar
25 Year Member
Well.. as far as engine, not much, but all the other features!
Front end, steering wheel, seats, wheels, interior!
Old Jan 16, 2003 | 07:47 PM
JOMO
Guest
Posts: n/a
maybe the gear ratios fucked him up, or maybe the other r's run better, modified maybe? all i know is they KICK ***!!!!!!!!!!
Old Jan 16, 2003 | 07:53 PM
Hooch'n's Avatar
The 96 pulls much better up high with different gearing, 98's seem to have great gearing in low gears.......Final Drive, 5th ex.
Old Jan 16, 2003 | 07:54 PM
ITR21's Avatar
could just be the driver. The gear ratios are shorter in the newer 5 lug models in japan which should HELP him. You would know if it is japanese by the front end. does it have 2 round lights?
Champ R's Avatar
Ive never heard of a 00 spec JDM R. Whats different between the 98 spec and 00 spec R's?
Old Jan 16, 2003 | 08:09 PM
skafia's Avatar
25 Year Member
Default Re: U.S. Type R vs JAP Type R (Champ R)
I'm thinking the intake cams, HID headlights, PY Exterior/Recaros, PY SRS Steering Wheel/shift boot, Production #'s... correct me if I'm wrong...
Old Jan 17, 2003 | 08:46 AM
sgT's Avatar
sgT
00 spec lol
i dont think so
Old Jan 17, 2003 | 09:02 AM
AoiGSR's Avatar
25 Year Member
Jomo,
From this point on, please refrain from using the word "Jap" as an abbreviated word for Japanese. JDM (Japanese Domestic Market), or JP (Japan), or JPN are abbreviations that are more widely used. Jap is considered derogatory and do not like to be called that. I know you did not intend to offend anyone but just FYI
-aoib0t, who hasn't posted anything for quite a while
Old Jan 17, 2003 | 09:13 AM
TypeR 01 886's Avatar
Default Re: U.S. Type R vs JAP Type R (AoiGSR)
JDM YUM! I need more of that on my ARH!
Old Jan 17, 2003 | 09:18 AM
sgT's Avatar
sgT
Jomo,
Thanks honkey
Old Jan 17, 2003 | 09:28 AM
yoshi234's Avatar
I shoot brides
Default Re: U.S. Type R vs JAP Type R (sgT)
Thanks honkey
Old Jan 17, 2003 | 09:32 AM
AoiGSR's Avatar
25 Year Member
sgT, j00 might want to check out http://home.powertech.no/morteas/derog.htm
honkey is also on that list
-aoib0t, who posts again. 2 posts in one day.
[Modified by AoiGSR, 10:38 AM 1/17/2003]
Old Jan 17, 2003 | 09:38 AM
skafia's Avatar
25 Year Member
That's soom good ****, lol. Zipperhead - haven't heard that since FMJ
Old Jan 17, 2003 | 09:42 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
What is the 96 spec ITr running.....EVO's and Skylines. You guys have a lot of those on the Island right. The ITR would get its *** handed to it but a stock EVO, WRX, Skyline etc (Esp if they are from Japan).
