tps
how much is a tps for a 91 civic si and can i just get one from a different model civic or crx...also my lower ball joints are bad and when i was trying to put the bolts on they just spin the stud...is there a way i can get them on with out getting new lower balljoints?
(i cant get new ones till i have a car to drive)
thanks
justin
thanks
justin
You may have to grind the two rivet type things off the donor and use some bolts on the new one. To this day I don't know why honda does that. And if you try and buy just a tps at the dealership they tell you that you need to buy the whole TB. pfffft.
And actually, you dont need to grind the head all the way off the rivet. If you can slot it for a screwdriver, they will just screw off.
88turdbucket
Feb 27, 2005 06:09 AM
