Taking door panels and front seats out (searched already)
Old Jan 16, 2003 | 06:28 PM
lo_95EJ's Avatar
Default Taking door panels and front seats out (searched already)
Hey everyone whats up!
im planning to take my interior apart and lurking around H-T i've noticed most of you guys have been through this process...so i need to exactly know how take my fronts seats out of my 95 Civic coupe and also how to take the door panels apart?
i've searched and didn't come up with anything...if there's something posted sorry, if not, i'll need most of you guys info
thanks!
Old Jan 16, 2003 | 06:51 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Taking door panels and front seats out (lo_95EJ)
there are 4 bolts holding in the front seats. Not much to explain.
Old Jan 16, 2003 | 06:53 PM
VTECVillain's Avatar
Seats are simple - 4 bolts each, unbolt, remove - simple as that. The door panels you need to remove the screw in behind the door handle and take the door handle cup out. Take the screw out in the door cup on the arm rest, remove the plastic cup and then the plastic screw below the mirror where the door panel is thin and closes against the dash. You need to take the wishbone clip off behind the window crank and remove the window crank. If you have power windows and locks then yo uneed to disconnect the wire clips. After that just be careful and pull around the edges to pop the snap clips free. Then lift out from the bottom and up at an angle on the door panel to remove it.
Old Jan 16, 2003 | 07:39 PM
lo_95EJ's Avatar
Default Re: Taking door panels and front seats out (VTECVillain)
Thanks alot guys!
Old Jan 16, 2003 | 08:08 PM
Slow CX's Avatar
Just remember when taking out the drivers seat there is a wire for the seat belt. Don't do what I did. I thought it was stuck and just started pullin it then I looked and saw the wire. It just a little clip.
Old Jan 16, 2003 | 08:25 PM
lo_95EJ's Avatar
Default Re: Taking door panels and front seats out (Slow CX)
hahaha thanks alot!
JRZ88DX
May 26, 2008 10:51 AM
raybord
Aug 11, 2004 04:59 PM
JDM EJ1 95
Mar 25, 2004 03:13 PM
sonicSVT
Mar 9, 2003 02:44 PM
itr-j
Apr 26, 2002 05:16 AM
