CRX DX, got it today...!!!!!!!
Old Jan 16, 2003 | 05:40 PM
bigblockEG's Avatar
Default CRX DX, got it today...!!!!!!!
Hey all, I picked up my new car today. It is a 90' DX CRX. I already have a 99' GSR ready to drop in. All I need to buy is some mounts, axles, and linkage, oh ecu + jumper and I am all done. Wish me luck guys. I will post some pics of the car in a few days...
Old Jan 16, 2003 | 06:31 PM
VTECVillain's Avatar
Default Re: CRX DX, got it today...!!!!!!! (bigblockEG)
Good to hear that you got a CRX. I built one for my finace - 91 CRX DX with 96 B18B1. I never get to drive it anymore Which tranny and mount kit are you planning on using?
Old Jan 16, 2003 | 06:37 PM
Default Re: CRX DX, got it today...!!!!!!! (VTECVillain)
Here's a pic of the motor setup. She won't let me boost it
Old Jan 17, 2003 | 07:56 PM
bigblockEG's Avatar
I am planning on going with a Kenji-made jumper to run a p72 and most likely hasport mounts and linkage, unless, the linkage is that easy to make. Do I need to get the Si hubs to fit the 90-93 teg axles?
Old Jan 17, 2003 | 07:58 PM
bigblockEG's Avatar
If I switch to obd-I, what distributor do I use... Obd - 1 right?
Old Jan 17, 2003 | 08:23 PM
The 90-93 Integra axles will fit the DX hubs. Only the CRX HF and Civic STD need to be changed the DX or Si hubs since they have a different amount of splines. I have the HASport billet mounts and shiftlinkage.
Old Jan 17, 2003 | 08:25 PM
If you plan to use the OBDI ECU, then you will want to use an OBDI distributor and injectors without a resistor box.
Old Jan 17, 2003 | 11:01 PM
ErikDaGenErik's Avatar
are you using a b16a cable tranny? or are you gonna convert to hydraulic tranny? plan sounds good, can't wait to see your setup when its done.
Old Jan 18, 2003 | 10:12 AM
bigblockEG's Avatar
Default Re: CRX DX, got it today...!!!!!!! (ErikDaGenErik)
I am going to use a cable tranny, not sure which one yet. When I am done I will post some pics
Old Jan 18, 2003 | 10:13 AM
bigblockEG's Avatar
Also, is there room for A/C. I heard that someone is working on a bracket to use B-series A/C in the 88-91's
Old Jan 18, 2003 | 10:25 AM
You can get the HASport A/C bracket and use your stock D series A/C compressor. It's a tight fit but there's no modifications needed, just bolts in.
90crxdx
Feb 23, 2005 01:37 AM
Red_Si
Dec 16, 2003 08:13 PM
projectcrx
Mar 26, 2003 09:57 PM
lil_1_2002
Feb 5, 2003 07:45 PM
