no vtec in the b16
Old Jan 16, 2003 | 05:14 PM
roninb18's Avatar
Default no vtec in the b16
We just put a b16a2 in my friends civic hatch. We found out it had a bad ecu but we got a new one and it is running. Now we can't get the vtec to engage. We have checked out all the wiring and the solenoid and everything is fine. Any ideas what it could be?
Old Jan 16, 2003 | 05:18 PM
HavokB18's Avatar
Default Re: no vtec in the b16 (roninb18)
Got oil? Sure you are running the proper ecu?
Old Jan 16, 2003 | 05:22 PM
roninb18's Avatar
Default Re: no vtec in the b16 (HavokB18)
Yes it has oil. We put the p72 in it. As far as we know that works with that motor. Any other suggestions?
Old Jan 16, 2003 | 06:03 PM
JDM92CX's Avatar
Try using brake cleaner and spray around the edge of the vtec sioldnoid. My friend did it last saturday cause his vtec wasn't kicking in. Once he did it...The sucka kicked in nicely! It wouldn't hurt if you try...
Old Jan 16, 2003 | 06:31 PM
blazinb16's Avatar
Default Re: no vtec in the b16 (xJDM88EF9x)
We'ver already tried all of that. What else could it be?
Old Jan 16, 2003 | 06:50 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: no vtec in the b16 (blazinb16)
low oil pressure
Old Jan 16, 2003 | 06:56 PM
blackANESE's Avatar
Default Re: no vtec in the b16 (Emerica)
If you are trying to hit VTEC before the car warms up it won't engage due to improper oil pressure as stated above.
Is your oil pan ok? If the oil pan is dented that too can cause problems.
Old Jan 16, 2003 | 07:09 PM
customx_'s Avatar
New User
this might be of help:
https://honda-tech.com/zerothread?id=164863
Old Jan 16, 2003 | 08:09 PM
MHill's Avatar
is the vehicle speed sensor hooked up?
this is soemthing people often overlook when hurrying to get a swap going
Old Jan 17, 2003 | 06:54 AM
apalma0609's Avatar
Check your knock sensor if it's hooked up. You should have 3 extra wires to hook up, vtec pressure, vtec solinoid, and knock sensor. Just double check those.
raverx3m
Jan 28, 2013 07:34 AM
jordan_rael_420
Sep 17, 2008 04:07 PM
hdsi94
Aug 23, 2006 03:53 PM
da9driver
24
Aug 25, 2005 01:00 PM
thehondaguru
Dec 31, 2002 03:23 AM
