is it possable to go from a cable speedo to an electric speedo? i need pics of the back of your gau
Old Jan 16, 2003 | 03:59 PM
Snail Tuning's Avatar
Default is it possable to go from a cable speedo to an electric speedo? i need pics of the back of your gau
ok im on my 4th cable speedo and its off by 20 mph. im done with tring to fix it. is it possable to go from cale to electric? i already have the electrice sending unit fromthe tranny so all i would really need is the electric speedo. has anyone done this and have pics? and if anyone has pics of thei gauge clusters from the back i could really really use them to determin hat speedometer mightwork.
thanks
Old Jan 17, 2003 | 04:52 AM
Default Re: is it possable to go from a cable speedo to an electric speedo? i need pics of the back of your
bump
Old Jan 17, 2003 | 05:53 AM
VTECVillain's Avatar
The JDM Civic/CRX SiR clusters use an electric speed sensor so I would assume that the Integra XSi does as well. If so, they would bolt right into your car and you can use most any Civic/Integra electric speed sensor on the tranny and wire it up to the cluster. If not, you might have to get a newer Civic/Integra cluster and rewire it and make it fit. Not sure though.
[Modified by VTECVillain, 9:56 AM 1/17/2003]
Old Jan 18, 2003 | 01:54 AM
NirSpec1's Avatar
I was wondering the same thing about the jdm sir cluster, I know the teg xsi is a cable cluster, I just got a complete front clip yesterday and was very suprised to find a cable speedo, but what whatever. I'm hoping that you can just hook up the speed sensor to the cluster, but there is a speed sensor wire in the ecu so i'm not 100% sure how that would work.??? I would say try to hook it upp directly to the cluster and see what happens, you may have a code and then vtec won't engage. I'm sure there is a speed sensor wire that runs from the cluster to the ecu in order to tell the ecu the speed of the car... I would love to get a 100% answer on this as well... soo someone help!!!!
peace
RACEPAK
Nov 9, 2023 07:24 AM
dannyb18c
May 11, 2012 02:04 PM
ben.batiste
Jan 7, 2010 07:20 AM
JapJunkie
13
Feb 1, 2007 02:30 PM
virginia_dude
25
Feb 1, 2004 06:38 PM
