speed bumps
Old Jan 16, 2003 | 02:48 PM
accordancewitstyle's Avatar
Default speed bumps
i am a military member and i live on
> base. Due to security measures our base has installed
> one of those speed bumps(fairly high) with the spikes on them. the
> problem i have is that my car has regular drop springs in it.
> And it sits 4in. off the ground. i was thinking about getting the car
> raised but i can not find springs that drop less than 2in. cause thats
> what i have in the car right now. I was thinking of coil overs but dont
> know jack about them!!!! can you recommend a type and not so expensive
> brand so i can take care of this problem? plus i dont want to loose the
> cornering i get out of the springs i have now. you know the rockering
> affect?
> i have a 91 honda accord auto. the scraeing noise is killing me
> everytime i go over the darn bump.
> thanks for any info you guys can provide
Old Jan 16, 2003 | 02:51 PM
ArchAngel Sabastian's Avatar
New User
Default Re: speed bumps (accordancewitstyle)
they make OE type springs with as little as 0.75 drop
try H&R and Neuspeed.
Old Jan 16, 2003 | 02:53 PM
urbanlegend21's Avatar
New User
Default Re: speed bumps (ArchAngel Sabastian)
you can get custom Eibach springs
Old Jan 16, 2003 | 07:04 PM
cyrixvsp2's Avatar
Default Re: speed bumps (urbanlegend21)
or stock.....i'm guessing putting stock size springs would raise your car, oh, maybe 2" higher....haha.
what base is there that's in NYC?
also, try a search for suspension, you'll find a TON of stuff on here, that's a common topic.
Old Jan 16, 2003 | 07:10 PM
ratherbewalking's Avatar
Default Re: speed bumps (cyrixvsp2)
you dont need to know alot about coilovers. they are fairly simple. only thing is id reccomend getting struts with a pair of chepo coilovers (cheapo bc you said you dont want to spend much money)
Old Jan 17, 2003 | 05:14 AM
johnsaccord's Avatar
Default Re: speed bumps (ratherbewalking)
airbags can solve all of your problems. you will be as low as you want to be whenever you want to be and then with the flip of a switch be up as heigh as stock to go over bumps, etc. just a thought. if not try eibach pro-kits or h&r oem sports.
Old Jan 17, 2003 | 09:29 AM
twkdCD595's Avatar
Default Re: speed bumps (johnsaccord)
I could not attempt a speed bump if I wanted too... btw my car has about 2-3 inches of clearance at most on the race springs.
dont eibach only drop it like 1.25-1.5 inches.
[Modified by twkdCD595, 10:34 AM 1/17/2003]
Old Jan 17, 2003 | 12:53 PM
Crono139's Avatar
Default Re: speed bumps (twkdCD595)
Go over speed bumps at 7mph, and at an angle. Best advice I can give you.
Old Jan 17, 2003 | 02:55 PM
jspark79's Avatar
Default Re: speed bumps (Crono139)
Hey Crono,
I never really understood the reason for going over bumps at an angle??
Is it only to prevent the see-saw motion from front to back?
Old Jan 17, 2003 | 04:41 PM
cyrixvsp2's Avatar
Default Re: speed bumps (jspark79)
my show truck lays frame and soon to be laying body so the question about going over bumps at an angle.
each tire will go over separately, so you can go over slow. if you go over like both front tires at the same time then the cars weight goes up and comes down at the same time which compresses the suspension and then the body of hte car will hit. if you do each tire at a different time less weight is unloaded and the body doesn't dip as much when you go over it.
Old Jan 17, 2003 | 10:23 PM
this man knows his ****! i tried everything, my car isnt even that low, but if you take them at a moderate speed, your car never goes down. it travels at the same heigth try it. and 7mph sounds about right
DannyBoy310
Apr 27, 2012 02:20 PM
rickytan24
Mar 8, 2007 06:34 AM
roman420
Jan 3, 2002 07:28 AM
