225/50/15 tires
anyone using 225/50/15 tires as daily tires? any rubbing if lowered? searched and didn't find anything about it. also, anyone have pics of the tires on a car?
yes they do,
http://www.tirerack.com/tires/Compar...m=1&pagemark=1
you will have to offset them a little more and buy a wider rim
i already have 15x6.5 rims with 42mm offset i think. just wanted to see if any is using them. already have 195/60/15 and deciding between 225/50/15 or 205/55/15.
i run the same kosei k1s. mine are +45 offset.
you will not be able to fit a 225 size tire on a 6.5" rim. *edit* safely anyway
[Modified by exaccord, 5:12 PM 1/16/2003]
Hey bro,
As far as I know with my Cord the max you can get are 215/45/17......oh wait. You are gonna put 15s on?? Thats small isn't it, why not go with 17/18s??
anyone have any pics of 205/55/15 or 225/50/15 on their car?
I'm wondering though, anyone get 225/50/15 tires onto 6.5" wide 4th gen Lude VTEC (the lighter non-Si) wheels on an accord? I'm thinking of going the cheap route w/ those wheels... but offset and fitment are a concern.
that link to tirerack shows Yokohama ES100's come in 225/50/15, and $80 a tire!
I had(sold) 225/50/15(Yoko AVS Int) on 15x6.5 92 prelude si wheels lowered on Neuspeed Sports, the offset is +55 and no rubbing issues on my 00 lx coupe mostly due to the fact that the wheel is so short. Tires did tend to bubble out while running high psi for road racing and made it wear in the middle slighly more than the edges.
[Modified by OEMaccord, 8:48 AM 1/17/2003]
On a 5th Gen Accord i don't think a 225/50/15 on a lude rim would fit. I have 205/50/15 AO32Rs on my Prelude VTEC rims, and there is literally 1mm of clearance between the rim itself and the upper control arm. The tire goes straight up so it doens't rub, but if you put a tire on it that bulged out like a 225, it would most likely rub. It's so close, it has knocked the wheel weights off the my wheels when I put them in the back.
