exedy clutch squeaking problem
Ok I have the exedy organic faced clutch and every time I start off and it engages I here a squeak. This happens when engaging 1st and reverse. I'm not sure about any other gear cuz my engine and exhaust drowns out the noise. Has anyone else experienced this problem????
From what I have learned is that the springs in the sprung hub come loose and squeak...
It could cause a problem but mine has been squeaking since the week after the install... So beware and if you could afford to replace go for it.
Mine didn't squek, but it had a very slight grinding noise. I had to adjust the push rod on the back of the clutch pedal so the release bearing wouldn't travel so far.
This is what the tech at Honda did when I was working there to cure the squeaking clutch.
While I was in the seat, he would be under the car and I am assuming the clutch slave cylinder, he would spray lithium grease in there, tell me to push the clutch pedal till it stops squeaking.
jdmspoonitr
Jun 21, 2006 10:02 AM
