tire help please
i need new tires, bad. unfortunately, i will have to put it on the credit card. any suggestions,recomendations will really help. i will probably spend around $100 per tire. i know everyone uses falken azenis, is there any better or equal?
i will be running 205-50-15 and will use them for aggressive street driving and hopefully some track schools
[Modified by cmdr430, 6:21 PM 1/16/2003]
what are you going to do with the tires? And search on tires, you'll find a number of threads. Azenis are good, inexpensive high performance tires that are OK in the rain, suck hard in the snow, don't like the cold, and wear out fairly quickly (such is the trade off for excellent dry performance)
Kumho 712 Escta or Yokohama AVS ES 100 are decent performance tires for under 100$. Check out www.tirerack.com to compare different tires and prices.
HTH
HTH
HTH
HTH
if you don't like or don't want to get azenis. Then the above choices should suit you fine.
Audi RS4
10
Aug 27, 2002 08:04 PM
