Dropped Cars
Old Jan 16, 2003 | 11:42 AM
1Tym's Avatar
Default Dropped Cars
I wanna drop my car sooo bad. Mine is just stock and I think the first thing I need it to lower it. NOW...what is a good setup? what do u guys think? I only have about $200-$300 to spend though. Any suggestions? If u have a stock integra that is dropped please post pics...THANKS
Old Jan 16, 2003 | 11:47 AM
hypnosisracing's Avatar
Default Re: Dropped Cars (Integra199)
Get some ground control coilovers if you just want that dropped look, they are made by Eibach, pretty decent setup, and they are usually around the $299 mark...then save to upgrade the rest of the suspension later...
Old Jan 16, 2003 | 04:36 PM
631 Teggy's Avatar
Default Re: Dropped Cars (hypnosisracing)
Your ganna need a lot more then just 400... I spent 1500 on my coilovers:
Old Jan 16, 2003 | 05:31 PM
B Speed's Avatar
Default Re: Dropped Cars (631 Teggy)
Do it right the first time and buy a true coil setup. (i.e., Tein SS, Apex'i Worldsport or N1, Buddy Club Racing Spec, and Zeal S6 are all good coil systems. I think all of them are adjustable with the exception of Buddy Club)
Old Jan 16, 2003 | 05:37 PM
MyVtec8u's Avatar
nice drop!
Old Jan 16, 2003 | 05:39 PM
bartek_b's Avatar
Default Re: Dropped Cars (MyVtech8u)
nice drop!
Old Jan 16, 2003 | 05:43 PM
TheRoxorcist's Avatar
Default Re: Dropped Cars (mugen85r)
Old Jan 16, 2003 | 05:52 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Dropped Cars (TheRoxorcist)
I went with the Neuspeed race springs and the KYB GR2's from Inlinefour.com. cost $400 with tax and shipping. I like it a lot
Old Jan 16, 2003 | 05:57 PM
Specs's Avatar
slam it..... [img]C:\Program Files\America Online 8.0\download\rnr intega 1.jpg[/img]
Old Jan 17, 2003 | 06:12 AM
Default Re: Dropped Cars (specs)
Skunk2 adjustable coilovers...$350 for the set about a year ago, ride is still somewhat decent for simple adjustable coilsprings...
Old Jan 17, 2003 | 07:47 AM
Tee Jay's Avatar
If you plan on dropping it more than 2'' you better save more money for some struts.
Old Jan 17, 2003 | 07:53 AM
jeebusm3's Avatar
Default Re: Dropped Cars (CrX_HF)
Go with Ground Control's. For $299 it'll do what you need. But you will blow your shocks after a while using any lowering springs on them. You might as well put some on at the same time. I went with KYB AGX with GC's. It was less than $700 for the whole package and the ride (because of adjustability) can go from pretty comfortable to go-kart like.
Old Jan 17, 2003 | 09:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
and it looks like you need to raise the rear end up some.
Old Jan 17, 2003 | 09:39 AM
Razor's Avatar
Default Re: Dropped Cars (PatrickGSR94)
yeah i was going to say, my car looked like when i installed my koni yellow shocks...it makes the rear sit lower and looks weird...thank goodness for height adjustable shocks. since you have coilovers, it wont' be a problem but you will most likely need to get an alignment for the rear.
Old Jan 17, 2003 | 01:32 PM
1Tym's Avatar
ok so far i've heard...Skunk2 or Ground Control adjustable coilovers. anymore suggestions?
Old Jan 17, 2003 | 01:42 PM
14eight's Avatar
Default Re: Dropped Cars (Dee Cee Two)
yah I agree, take out a small business loan and do it RIGHT!!!
ok well considering we know that he only has about 400 to spend and thats cleaning out the cracks of his sofas and his grandmas sofas he cant afford true coil setup. So with that in mind, id say to get the best bang for your buck, a nice spring and shock combo. like those neuspeeds springs look nice, and then do a nice shock AGX or tokico. nothing too crazy. There is no point in spending more money than you have to for what you need. If your goal is to have a slammed car with a fairly decent ride comfort than a simple shock spring setup will suit you fine. If your goal is to join the SCCA and bring home tropheys then save up.
done.
Old Jan 17, 2003 | 01:49 PM
qcoffey's Avatar
Default Re: Dropped Cars (14eight)
I think that a coilover isn't always necessary. I have coilovers and if I didn't go to shows they would never get adjusted. When I'm on the street or auto-x course they don't get touched. I would reccommend going with a good spring and shock combo. I like the H&R Race springs(I had them before my Ground-Controls). If you combine a good non-adjustable strut like the Tokico HP you could get out the door for under $400. Remember to factor in a little extra bread for an alignment.
Good Luck.
Old Jan 17, 2003 | 01:50 PM
ItzTw's Avatar
Get Maxspeed Coilovers, They have the same Spec's as Skunk2. Exactly Identical
Old Jan 17, 2003 | 01:57 PM
Adampops's Avatar
Default Re: Dropped Cars (ItzTw)
Keep saving and get some H&R Cup kits. Shock and spring combo. No adjustability height wise but chances are youll find the right height and wont touch them again. 2" in the front and 1.75" in the rear is perfect.
Old Jan 17, 2003 | 06:23 PM
1Tym's Avatar
Default Re: Dropped Cars (Adampops)
thanks guys..and btw...i'm a girl not a guy...nice assumption though
Old Jan 17, 2003 | 06:46 PM
SiK AcC0rD's Avatar
nice, girl racers HEHE...save some more $, u wont regret doing this...the suspension of ur car is the most important thing. get something worth ur money..and its gonna cost around 1000 for everything or a lil more...things u have to consider if u want over a 2inch drop, coilovers, shocks, camber kit & alignment. gluck
-James
Old Jan 17, 2003 | 08:43 PM
civic dx's Avatar
Default Re: Dropped Cars (SiK AcC0rD)
2" drop on tanabe springs
[Modified by civic dx, 11:44 PM 1/17/2003]
Old Jan 17, 2003 | 08:44 PM
EK MONEY's Avatar
Default Re: Dropped Cars (civic dx)
1800, tein RE. Check my sig..
Old Jan 17, 2003 | 09:01 PM
KtownEG's Avatar
This car is very clean
Old Jan 17, 2003 | 11:51 PM
yo mikey's Avatar
Default Re: Dropped Cars (SpoonFedEG)
i recommend skunk2 coilovers. they drop really nice. lower than ground controls do.
