axels
ok i got the info on parts needed to swap the b16 into a 4th gen hb, now that axel **** is confusing on hasport.com can anyone sum up what axels are needed??/ also what clutch do we use???
People that order their swaps that come with axles usually come with 2 different ones: one is the SiR setup, which is the SiR intermediate shaft and SiR axles. The SiR axles are not available here in the USA, but they can be made from a hybrid of 2 integra axles. This usually comes with the Y1 transmission.
The other usually comes with the JDM S1 or J1 transmission. These axles are identical to 90-93 integra axles, as is the intermediate shaft.
If you didn't get axles with your swap, I'd go after 90-93 integra axles and intermediate shaft. They are easy to find replacements for and you'll probably pay less.
HTH
HTH
so u don't have rip apart a bunch of differnet axels??? thats what i was getting from the description at hasport. is a Y1 tranny LSD??? we are gonna to pick one up for a friend this weekend and just trying to find out what to look for.
some y1 trannies have lsd some dont. You will need a 90-93 integra axles and intermediate shaft as well. if not email or call http://www.crxguru.com
As for the cluch you need to get the year that would go with the tranny. 90-91 clutch disc are different then 92-93. Axles just use 90-93 teg axles and intermediate shaft its all the same as long as there from a 5sp, not automatic
[Modified by zCivic, 12:38 PM 1/16/2003]
If you find out you have the SiR intermediate shaft and want to axles to match it, http://www.raxles.com sells them.
24hourflipness
31
Apr 29, 2003 08:50 PM
