LS into EG swap questions
ok, this might be a semi-newbie swap question, but atleast im tryin, so here it goes.
when swappin in a 1991 LS engine into a 94 CX, besides the Motor, Tranny, ECU, and motor mounts, what else will i need? do i absolutely need the tegra axles, or can i use the civic ones? i remember hearing problems with the lengths of the civic hb ones when using the B series engines. also, and insight or tips to the swap would be greatly appreciated.
Hmm...All these questions would be easily solvable by doing a search, or even researching. Basic knowledge tells you that it is nearly pointless to swap a OBD0 into a OBDI shell. B18B's are a dime a dozen, You should be able to acquire them for about 1300-1800. The mounts on the B18A are different than that of the Civic, the axles, linkage are different aswell, but you would know what fits if you did a search.
http://www.osakajdmmotors.com
http://www.hmotorsonline.com
http://www.SOHfast.com
http://www.ardperformance.com
there are a few more, just can't think at this hour. search and you'll find them.
buy a 94-up Integra swap complete with mounts,linkage and axles and bolt it in.
jdmeg1075
May 8, 2009 09:35 AM
seeeya04
Jun 6, 2005 06:06 PM
