4 generation lude, rear window defroster...
is it only me or the rear window defroster on a 4 generation lude a bit slow.. it takes like 20 mins for the rear window to be clear, is there a faster way i can clear it .. besides using a manual wipper.. =|
also... where can i get replacement windows.. i may need to replace them
Mine clears real quick too. Do you have tint on your rear window? If you do, then maybe whoever put the tint on messed up your defroster.
by the lines out i meant that if there is a break in one or more lines, causing the line/lines that have breaks in them to not work and the others will
StockDC2
Dec 20, 2008 10:13 PM
