* Motor Oil Poll
Old Jan 15, 2003 | 07:22 PM
Chris y0!'s Avatar
Default * Motor Oil Poll
what do you run in your civic?
Old Jan 15, 2003 | 07:24 PM
Chris y0!'s Avatar
Default Re: * Motor Oil Poll (Spoon Hybrid)
i left the poll open for a reason, so you can add what kind of oil you use. please don't add anything stupid. thanks.
[Modified by Spoon Hybrid, 4:25 AM 1/16/2003]
Old Jan 15, 2003 | 07:28 PM
-Whitey-'s Avatar
castrol syntec
Old Jan 15, 2003 | 07:30 PM
sleeprhatch's Avatar
castrol 5w-40w
the only place i know were to get this stuff is at the VW dealer
Old Jan 15, 2003 | 07:44 PM
91SIvic's Avatar
Default Re: * Motor Oil Poll (sleeprhatch)
you guys do know that has yet to be proven that any oil is better than another oil.
Old Jan 15, 2003 | 08:14 PM
oldB18EF's Avatar
Default Re: * Motor Oil Poll (91SIvic)
i use mobil 1 5w-30
Old Jan 15, 2003 | 08:17 PM
976's Avatar
976
New User
Default Re: * Motor Oil Poll (WR93EG)
What is the poll for?
Performance, protection, race?
Just over all? I'd agree with pretty much everyone else, Mobile 1.
Valvoline for performance.
Kendal 20w40 race.
Average protection Mobile 1.
IMHO.
Old Jan 15, 2003 | 08:25 PM
Simple's Avatar
Default Re: * Motor Oil Poll (w00t!)
kendal oil over here run it in my B20Vtec ej
Old Jan 15, 2003 | 08:51 PM
.Beaver's Avatar
Bloody Beaver
Default Re: * Motor Oil Poll (Simple)
Valvoline Dura Blend $2.19/ quart
Old Jan 15, 2003 | 09:16 PM
BackSideSA's Avatar
Default Re: * Motor Oil Poll (93 MR EJ1)
canola oil works good
Old Jan 15, 2003 | 09:31 PM
Lysawy's Avatar
Default Re: * Motor Oil Poll (HybridHackBatch)
castrol syntec 10-30 4.47$ a quart but hey my baby deserves that anyways...
Old Jan 15, 2003 | 09:55 PM
.Beaver's Avatar
Bloody Beaver
Default Re: * Motor Oil Poll (Lysawy)
yeah my almost stock D16Z6 better suck me off if I spent that much on oil.
Old Jan 15, 2003 | 09:56 PM
eg_nezay's Avatar
I use mobil 10-30 fully synthetic
Old Jan 15, 2003 | 10:17 PM
94hondaLS's Avatar
its not about if one oil is better than another. its about how long and well the oil protects from viscosity breakdown. so technically one may be better than another. and Oh yeah I use castrol syntec 10w30 in my eg w/b18b
Old Jan 16, 2003 | 03:02 AM
If You Slip You Die's Avatar
Default Re: * Motor Oil Poll (94hondaLS)
NEO SYNTHETIC OIL
Old Jan 16, 2003 | 04:57 AM
Ceeveek's Avatar
New User
Default Re: * Motor Oil Poll (lilxjoker)
HAHAHAHAHAHA!
Old Jan 16, 2003 | 05:57 AM
Kalokohan's Avatar
New User
Default Re: * Motor Oil Poll (Ceeveek)
Nobody uses Pina Colada Butt Oil?
Old Jan 16, 2003 | 06:47 AM
BLK JDM's Avatar
I run Mobil 1 5W-30 & 10W-30 Depending on what time of year. I believe in Mobil 1. If Ferrari and Porshe and Bentley only run Mobil 1, why can't my little beater run just as good. My Del Sol deserves the best!!!
Old Jan 16, 2003 | 08:08 AM
GTIman1212's Avatar
Default Re: * Motor Oil Poll (jigga008_99)
mobil one in my dub
Old Jan 16, 2003 | 08:12 AM
Adriano's Avatar
this is what i use
j/k..i use mobil syntec blend 5-30w i think
[Modified by brryder, 5:13 PM 1/16/2003]
Old Jan 16, 2003 | 10:02 AM
Shawn C's Avatar
In The Garage
Default Re: * Motor Oil Poll (brryder)
well, as for one oil not outperforming another oil, thats not true. A few years back, Pennzoil did a test on conventional vs. full synthetic. they took 2 brand new GM engines, put conventional in one, and full synthetic in the other. they ran them both for 80,000 miles, changing the oil every 3000 miles, then broke them down and checked them with really expensive digital micrometers. the conventional engine had ~38% wear, average for a domestic engine w/ 80,000 on it. then they tested the engine with full synthetic. it had less than 1% wear. so this proved that full synthetic far outperforms conventional oil. also, just a little piece of information for you guys. Pennzoil and Valvoline are the USs best oil companies, they refine their own oil. Castrol buys the cheapest oil on the market and slaps their label on it. IMO i wouldnt put castrol in my engine if i was 1.5 quarts low and its all i had. All they have is advertising, their oil sucks. And valvoline does a lot of Pennzoil's R&D for them, so i go with valvoline. its really good stuff. either that or pennzoil. redline, neo, etc. also make very good products, if you can afford them. Mobil 1 is good, but conventional Mobil sucks.
Old Jan 16, 2003 | 10:21 AM
ejprimo's Avatar
Default Re: * Motor Oil Poll (22lbGS-R)
i use mobil 1 10w-30 b/c it is the only over-the-counter (kragen, pep boys, autozone) motor oil which is a true synthetic meaning it is made from a group IV basestock. castrol syntec, valvoline synthetic, and pennzoil synthetic are made from a group III base stock (dino oil) and are refined to the point where it can be called a synthetic. also mobil one oil contains molybdenum which protects your engine parts. for more on moly go to : http://www.bobistheoilguy.com/moly.html. castrol syntec contains no moly at all whereas castrol gtx does. some peole feel that castrol gtx is a better oil than castol syntec because of this reason.
Old Jan 16, 2003 | 10:42 AM
CHRIS 1.8's Avatar
Mobil 1 10w-30 super-syn
Old Jan 16, 2003 | 11:24 AM
Hbgsr's Avatar
Default Re: * Motor Oil Poll (B16A1-EF8)
I used to run Mobil one 5-30 full synthetic, then I put redline in and I could actually tell a difference. I know that sounds kinda ricey but Im not kiddin, it idles better and runs better top end. My 2 cents.
Old Jan 16, 2003 | 12:04 PM
Pengo's Avatar
Default Re: * Motor Oil Poll (Hbgsr)
used to use mobile full synth but found castrol GTX much cheaper and just at good. oil changes regularly every 1-1.5k anyway
