rear lower trailing arm
Old Jan 15, 2003 | 04:11 PM
15psi of fun's Avatar
Default rear lower trailing arm
REAR LOWER TRAILING ARM and the little COMPENSATOR arm that connects onto the trailing arm it's number 12 (in the pic) im trying to get the bolt number 33 (in pic) out but the nut that is billt into the car is spinning how the hell do i get it out
it a 91 civic so its rusted
[IMG][/IMG] http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
[Modified by EFrollingout, 7:14 PM 1/16/2003]
Old Jan 15, 2003 | 05:29 PM
Default Re: rear lower trailing arm (EFrollingout)
OK nobody wonts to help with that
then what is the best way to get out a rusted bolt i have been using liquid wrech and im about to put some heat on it but its in a tight place and its going to burn the **** out of the bottom of my car.
Thanks to anybody that helps
Old Jan 15, 2003 | 06:52 PM
ChiBoy's Avatar
Pic doesn't work.
Old Jan 16, 2003 | 10:16 AM
Default Re: rear lower trailing arm (ChiBoy)
now the pic works thanks
Old Jan 16, 2003 | 02:38 PM
ejprimo's Avatar
heres the pic:
Old Jan 16, 2003 | 06:07 PM
tominos's Avatar
Default Re: rear lower trailing arm (ejprimo)
why don't you hold the spinning end with a wrench or vice grip or whatever? #12 looks like the whole arm, theres a nut on that?
Old Jan 16, 2003 | 06:40 PM
ChiBoy's Avatar
Default Re: rear lower trailing arm (tominos)
The nut is on a slider and is in a track sealed in the chassis. It slides so you can adjust the toe in the rear. The nut is designed NOT to spin in the track, but obviously, he has a problem. This might be one for the pros.
Could you buy that "nut" from Honda and install it??
Old Jan 16, 2003 | 06:45 PM
Jaker's Avatar
I had that happen a while ago (about 10 years). The only solution that I could come up with was to take a hole saw in the drill, find the approximate location for the head of the bolt, inside the car, and drill out the unibody to get to the nut from the other side. Its in that panel that goes from the bottom of the rear seat cushion down to the floor. Then you can seal it up with a metal patch held on with rivets, and sealed up with silicone.
Old Jan 16, 2003 | 07:05 PM
Default Re: rear lower trailing arm (Jaker)
ya i was thinking about cuting a hole but dame i don't wont to do that but if that things isn't saposte to be turning then i think that what i have to to
any other ideas
thanks for the help
Old Jan 16, 2003 | 07:08 PM
and thanks ChiBoy and Jaker
hovic
Suspension & Brakes
Dec 7, 2007 11:32 PM
VTECIntegra9
Feb 12, 2004 12:05 PM
Kolijian
Jan 13, 2003 10:37 AM
RoAnSa
Nov 23, 2002 09:08 AM
