once again, i need help ASAP! [turn signal]
Old Jan 15, 2003 | 04:03 PM
AH Tow EX's Avatar
Default once again, i need help ASAP! [turn signal]
EDIT: i fixed that ****!!! woo hoo! it was fuse 26, but under the dash, they are numbered up to 23, so there was this white connector that didn't have a fuse in it, so i put one in, and it works!!!!!!!! woo hoo! thanks for all the help guys! for everyone!
[Modified by AH Tow Ex, 2:06 AM 1/16/2003]
Old Jan 15, 2003 | 04:09 PM
AH Tow EX's Avatar
Default Re: once again, i need help ASAP! [turn signal] (AH Tow Ex)
oh no you don't. get back up there.
Old Jan 15, 2003 | 04:21 PM
Mikey's Avatar
Here you go, buddy.
Let me know if you need anything else.
Old Jan 15, 2003 | 04:24 PM
Mikey's Avatar
Default Re: once again, i need help ASAP! [turn signal] (Mikey)
I read your reply to your other post:
"i replaced the ************, and it still didn't work. ******* ten motherfucking dollars for that ******* piece of flaming useless **** that took a day and a half to pull out. what number is the fuse??????? because that ******* relay is not the right ******* answer"
If you already replaced this relay, then the problem is obviously NOT the relay itself. You need to further investigate your electrical problem.
Old Jan 15, 2003 | 04:27 PM
AH Tow EX's Avatar
hey thanks for the picture, but i replaced the relay already, and nothing. if this helps, my hazards work, but not my turn signals...
Old Jan 15, 2003 | 04:31 PM
AH Tow EX's Avatar
what happened to that post by the guy with beavis in his avatar? i saw it for a second, enough to read that it was fuse 22, and now it's gone. am i going crazy????
Old Jan 15, 2003 | 04:34 PM
AH Tow EX's Avatar
anyway, i replaced fuse 22 and it wasn't the right one. what could be the f'ing problem???
Old Jan 15, 2003 | 04:41 PM
AK94GSR's Avatar
You got the right kind of bulbs in there????
i had a problem like this on my outside corner markers, i had the wrong size bulb in there and they just stopped working, messed with the wires and the fuses but nothing. then i replaced them with another bulb and they work fine now.
just a thought
Old Jan 15, 2003 | 04:43 PM
AH Tow EX's Avatar
Default Re: once again, i need help ASAP! [turn signal] (AK94GSR)
yeah, i replaced my bulbs a bunch of times, and they're the right ones. thanks anyway though.
Old Jan 15, 2003 | 04:47 PM
tony4311's Avatar
yeah the link screwed up but I didnt rehost it because of the other post.
Mikey's Avatar
Do both lights turn on when you turn on both driving or parking lights?
[Modified by Mikey, 7:47 PM 1/15/2003]
Old Jan 15, 2003 | 04:48 PM
AH Tow EX's Avatar
driving lights? yes.
parking lights? no.
dwuknoit
Nov 29, 2008 06:46 AM
jinteg730
Oct 24, 2006 11:27 AM
AH Tow EX
Jan 26, 2003 10:00 PM
AH Tow EX
Jan 15, 2003 03:56 PM
