will h22 tranny fit h23
Old Jan 15, 2003 | 03:31 PM
h23accordlude's Avatar
Default will h22 tranny fit h23
Hey does anyone know if the tranny from the prelude vtec will work with the h23 motor.
I have a h23 prelude si motor in my accord and i'm thinking of swapping the tranny for the vtec tranny from the prelude
Thanks
Old Jan 15, 2003 | 03:39 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: will h22 tranny fit h23 (h23accordlude)
yes, it will fit
Old Jan 15, 2003 | 04:59 PM
str8rcn's Avatar
Default Re: will h22 tranny fit h23 (Boosted97Lude)
Yes i have one in my 93 si.A little closer ratio seems to pull a little better then the h23 tranny.
Old Jan 15, 2003 | 06:24 PM
PrecisionH23a's Avatar
the h23 tranny is better for boosted applications and the h22 is better for all motor, just thought id share that.
Old Jan 15, 2003 | 06:25 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: will h22 tranny fit h23 (GudeH23a)
why do you say that?
Old Jan 15, 2003 | 06:27 PM
DsITR's Avatar
lower gearing(should say too low)=spinning/burn out.
higher gearing=better traction
thats all I can come up w/
Old Jan 15, 2003 | 07:57 PM
AndyD's Avatar
Default Re: will h22 tranny fit h23 (dsludefosho)
Longer gears means that you can stay on the boost longer. Shorter gears means you have to shift earlier....less time to use the boost.
Old Jan 16, 2003 | 06:47 PM
b16b hatch's Avatar
Default Re: will h22 tranny fit h23 (AndyD)
From all I have researched the vtec and non vtec have the same gearing on them I have a 96 h22 vtec and the helms say they are the same.
Old Jan 16, 2003 | 06:53 PM
Cottonwoodz's Avatar
Default Re: will h22 tranny fit h23 (b16b hatch)
H23A1
1st: 3.31
2nd: 1.86
3rd: 1.32
4th: 1.03
5th: 0.81
6th (if availble): 0
Reverse: 0
Final Drive: 4.27
H22A1
1st: 3.31
2nd: 1.95
3rd: 1.36
4th: 1.07
5th: 0.87
Reverse: 0
Final Drive: 4.27
H22A4
1st: 3.285
2nd: 1.956
3rd: 1.344
4th: 1.071
5th: 0.87
Reverse: 0
Final Drive: 4.062
[Modified by Cottonwoodz, 9:55 PM 1/16/2003]
Old Jan 17, 2003 | 02:27 AM
Boostless97Lude
Guest
Posts: n/a
WOW!!! did u read that in Super Street???? shorter gears mean faster acceleration, which mean lower times , but traction can be a bitch.... so i think the idea is that with longer gears, you get less wheelspin and more traction
Old Jan 17, 2003 | 05:38 PM
Furry
Guest
Posts: n/a
http://www.preludecrazy.com
they have a comparo page where you can see the ratios for any 4th gen lude
Old Jan 17, 2003 | 05:40 PM
KW2000's Avatar
Default Re: will h22 tranny fit h23 (Furry)
i dun remember where i heard it but i heard that h22a1 tranny with a h23a1 motor will make it faster but will only top out at like 90 dunno where i heard it this true? it had something todo with the rev limit or something dunno
[Modified by KW93LUDE, 2:40 AM 1/18/2003]
Old Jan 17, 2003 | 08:15 PM
ViZ's Avatar
ViZ
Default Re: will h22 tranny fit h23 (KW93LUDE)
btw all H series and F series trannys are interchangable
Old Jan 18, 2003 | 06:04 AM
optikal_blitz's Avatar
Default Re: will h22 tranny fit h23 (ViZ)
there was a similarly discussed topic wherin they said the best tranny setup for an h-series would be gears 1 thru 3 from the h22 and 4-5 swapped with those of the h23..so you get quick acceleration and wide open 4 and 5 gears..how hard would this be to do..if the aforementioned is actually true?
Old Jan 18, 2003 | 12:32 PM
Sam, youre a good guy but dont be so quick to jump on this guys ***. He's actually correct, the longer the gear the better for turbo in most cases. A similar issue is all the turbo gsr guys that swap out to the ls trannys for their longer gears. We know the shorter the gear the faster the acceleration, you are correct with that. But with turbo's, you have to spool up as im sure you already know. When you just reach maximum boost on a short geared tranny youll have to change gears, then the turbo will have to spool back up. The longer the gears the longer you can stay at peak boost and not have to worry about shifting. Come down here and ill have my friend take you for a ride in his turbo b18c5, then you'll see why it sucks to have short gears in a boosted car. Anyways, heres a little tranny info for everyone:
the number specified for each gear is equal to the amount of rotations of the engine compared to the output shaft of the tranny. In other words...4.09 first gear= 4.09 revolutuions of the engine per revolution of the tranny output shaft. This is going to give you more power and rev up faster. As you upshift, the gears need to be longer to compensate for the car/wheels moving at a faster rate. The "gear" ratios will determine the rpm loss from upshifts,and the final drive will determine how much faster the gears will rev up.
[Modified by GudeH23a, 4:33 PM 1/18/2003]
Old Jan 18, 2003 | 12:57 PM
Boostless97Lude
Guest
Posts: n/a
but it is not neccesarily true about "staying in boost longer" i mean, if you have a big *** turbo and need a lot of time to spool up, then yes, longer gears would be better, but in my case, where as my turbo spools up pretty damn fast, than the H22 tranny will help my acceleration better and be better for me than a H23 tranny
Old Jan 18, 2003 | 02:15 PM
theoretically a h23a tranny would be better for you, end of discussion.
Old Jan 18, 2003 | 05:57 PM
Accord94DX's Avatar
h23a1 tranny + turboed f22b2 is smoof.
dspinz9747
Mar 13, 2009 05:56 PM
vtec fan
Sep 21, 2003 03:50 PM
95h23lude
May 2, 2003 07:56 AM
h23accordlude
Jan 15, 2003 06:34 PM
