Changing Transmission Fliud
Old Jan 15, 2003 | 02:09 PM
Casual Gcode1's Avatar
Default Changing Transmission Fliud
I need help trying to change this transmission fliud. Do I need a new filter? Where is the drain plug. Is there a transmission dipstick and if there isnt were do I put the fluid in at? Any other helpful hints?
Old Jan 15, 2003 | 02:24 PM
laughinxxx's Avatar
New User
Default Re: Changing Transmission Fliud (Casual Gcode1)
The drain bolt is on the passenger side of the tranny and will be the lowest bolt that you find. On my car it has a square depression in it, which a 3/8" drive rachet will fit. The fill bolt is almost directly above it. It will take 2 qrts to fill it up. I pulling the intake tube and snaked a hose down to the fill bolt to make replacing the fluid easier.
Edit: When fluid starts pouring out of the fill hole you have enough fluid in the tranny.
[Modified by laughinxxx, 3:26 PM 1/15/2003]
Old Jan 15, 2003 | 02:26 PM
Si_LuDer's Avatar
Default Re: Changing Transmission Fliud (laughinxxx)
I think on most of the H engines the dipstick will be located on the left side of the engine beneath the distributor cap.. it has a yellow handle on it!
Old Jan 15, 2003 | 02:46 PM
Thanks....is there a filter I have to change? Is the fill hole on the side of the transmission?
Old Jan 15, 2003 | 02:53 PM
laughinxxx's Avatar
New User
1. No
2. Facing passenger side
Old Jan 15, 2003 | 04:45 PM
SuperSH's Avatar
Maby we should ask if the tranny is auto or manual. Changing the fluid is diffrent for each.
Old Jan 15, 2003 | 06:19 PM
Default Re: Changing Transmission Fliud (SuperSH)
Manual...What else can you tell me?
GSRWSU
Acura TL, RL & ZDX
Aug 26, 2009 06:08 PM
GSRWSU
Transmission & Drivetrain
Jun 25, 2009 03:26 PM
jwrape
Jul 13, 2006 03:06 AM
ocdcivic
Dec 11, 2004 10:11 AM
Kyles ej1
Sep 23, 2004 04:41 PM
