Which distributor can i use?
92-95 GSR, 94-95 DOHC VTEC Delsol or 92-95 LS (with modification). Also (if you are really desparate), it is my understanding that the only diff between the obd1 and obd2 dist's is the plug (the actual internals and mount are identical) so you could also use an obd2 dist, but you will have to repin the plug to match your obd1 harness or swap the internals.
Thanx JeffC
I called Osaka and they said they'd send me one tommorrow, so we'll see if they can earn some of my respect back
[Modified by Gray EG on Jack Stands, 7:50 PM 1/15/2003]
efdrifter
Nov 8, 2007 09:14 AM
