Guidelines for installing a weak turbo on a f22.
I want to know if anyone has intstalled a turbo on a f22 in a 1992 accord. I want to know what type of turbo you used and some guidelines on how to install it. And yes I know its a aluminum block so thats why i'm installing a weak turbo.
They have those cool eletric turbo fans that you can hook to your intake .. .that should be about as weak as you can go
[Modified by Accord_Munch, 12:27 PM 1/15/2003]
[QUOTE]They have those cool eletric turbo fans that you can hook to your intake .. .that should be about as weak as you can go
that's REALLY weak!
[Modified by notoriousB, 8:40 PM 1/15/2003]
that's REALLY weak!
Ok your right, sorry .. was just trying to be funny ...
To answer your question above, I would just look at getting either an FMAX or Drag Gen 4 kit ... you can run 6psi easy with no issues. Look at around $4k installed if you buy the kit and have someone install it for you.
[Modified by Accord_Munch, 12:47 PM 1/15/2003]
