parts needed to do ITR swap in 4dr EG
I have already tried search and that is not giving me what I need. I know that this is a simple swap, I just need a list of what exactly is needed to do this swap.
Engine Swap: B18C5
Vehicle: 92-95 Civic EX 4dr
Budget: $8500
The car still has to be bought and I have found several prices, none over $3000.
The engine I estimate $4000-$4500.
That leaves me with about $1000-$1500 leftover.
Engine Swap: B18C5
Budget: $8500
you prolly will end up needing extra parts like hose and what nots. i would also get a clutch for it and maybe upgrade the radiator to a fluidine or a teg one. there will be a few other little things that come up to but other than that everything should bolt right in. you might have to swap some of the plugs since the engine is newer than the car or you will have to replace parts with obd1 parts liek the injectors and the distributor and the alternator. Rewiring the obd2 plugs onto the obd1 harness isn't to hard though.
jesse
jesse
bro buy the car first... then worry about the swap ... you never know you might be in need of brakes.. and your gonna want a good suspension soo... you see my point
