OT: How to clean valve cover?
Simple Green owns you Dan.
Finally got my hondata intake gasket in Chris. The TB stays cool as hell. Yes, guys i like feeling up on my TB now.
Did you install it yourself?? How was it? Looks like a b*tch to install.
Chris - who would like one of them there gaskets.
I was going to quit when i thought i losted a washer. But some how I found the little f@#$er and completed the install.
if you really want hat red to shine on your valve cover use vaseline. i swear it works wonders. put a light coat over the valve cover after it is all clean using simple green and a toothbrush and let it sit over night. then wipe off the excess really good and then put it back on. it really works. I am getting ready to re-do my valve cover using it soon
Well... I tried simple green the other day and it seems a bit rough on the paint. My towel comes up red! It also leaves the valve cover looking dry and white.
I used armor all and it worked fine removing oil stains off my valve cover.
To the guys that use simple green, do you wash out your engine bay using a hose after you're through?
I remember hearing that simple green came in a wipe form for those of us that are nervous about spraying water in our engine bay.
J00 gotta dilute the simple green.
good stuff to know
for the future of course
i always just lay a towlel doubled over on my red valve cover to lay my tools on and to rest my greazy *** hands on when i have to suport my self to work on the back of the motor from the top of the car
armor all................
I gotta try that,since mine is kinda dirty right now
[Modified by ITR GURU, 4:53 AM 1/16/2003]
What is the best cleaner that would get it off?
