Does 3rd gen share thermostat and fan switch with any other honda?
Old Jan 15, 2003 | 04:16 AM
jay f.'s Avatar
Default Does 3rd gen share thermostat and fan switch with any other honda?
I'm trying to cross referene part numbers and it seems that no other hondas have the same parts. I thought maybe the b series fan switch might work..but it has a different part number. The reason i ask is because i want a lower temp thermostat (which i think i can get at local parts store) and a lower temp fan switch from like mugen or spoon, but they only have them for pretty much every other honda acura but the 3rd gen..ie 92-95 civic, 94-up integra, h22 prelude etc. thanks for any help
jay f.
Old Jan 15, 2003 | 06:19 AM
3gLudeH22A's Avatar
Default Re: Does 3rd gen share thermostat and fan switch with any other honda? (jay f.)
Not sure, but you can PM 90crxlude....he may know. If not check these sites..
http://www.honda-prelude.com
http://www.3rdgenprelude.com
Old Jan 15, 2003 | 12:10 PM
hatchblack's Avatar
all you have to do is go to a parts store and ask for a 180 degree thermostat and they can give you one. i bought mine at advance auto parts. they stock the 180 and 195 thermostat. as for the cooler radiator fan switch, i would say buy the cooler switch and if you have to, just go to a junkyard and cut the clip off a civic or something that will fit the switch. then just wire it into your prelude. i believe there are two wires, or maybe there is just one. either way, just wire it in and you have the cooler fan switch.
G. Man
Aug 28, 2011 12:21 PM
eghatchneeded
Oct 14, 2008 03:03 PM
[TEAG]LuvMyDB8
Jun 2, 2008 06:57 PM
JDM_Type-R
Jun 16, 2002 08:31 PM
