high idle\ wont drive in gear
Old Jan 14, 2003 | 08:11 PM
2faz2paz's Avatar
Default high idle\ wont drive in gear
ok i have searched and found a few things but not everything. ok my car is idleing at 1500 when i start it up then it goes down to 1100 or so. i am guessing that it is a bad gasket on the throttle body because when i sprayed some wd40 on there it dropped some. but when i reversed it out of the driveway it was fine but when i put it in first gear and tried to pull it forward it seemed like it didnt want to go and then died all of a sudden. i have to floor it to get it to move and the rpms go up but when i pull it forward the tach doesnt move at all. i am not sure what is going on and need help badly. thanks in advanced
Old Jan 15, 2003 | 09:04 AM
2faz2paz's Avatar
Default Re: high idle\ wont drive in gear (2faz2paz)
ttt
Old Jan 15, 2003 | 09:29 AM
slowdx's Avatar
WD40???? But the high idle is just cause it has to warm up once it goes to normal operating temp it goes down, does about the same thing wiht my gsr motor.
Just my 2 cents
Old Jan 16, 2003 | 12:03 PM
maxpsi's Avatar
Default Re: high idle\ wont drive in gear (slowdx)
What if it doesn't go down and you have to reset the ECU to get a normal idle????
Old Jan 17, 2003 | 10:34 AM
2faz2paz's Avatar
Default Re: high idle\ wont drive in gear (maxpsi)
ok well does anyone know what the problem would be with the car not wanting to drive anywhere i can get it to move for a little while in first but the speedo doesnt even move
DuecedSol
Honda Civic (2006 - 2015)
10
Aug 8, 2014 07:26 PM
cstone
Jan 17, 2011 07:42 PM
amaq
Jun 25, 2010 05:51 AM
MLevinson
Jun 22, 2008 06:35 PM
raene
Nov 7, 2002 08:21 PM
