Squeaky Suspension...Spray Lube??
Old Jan 14, 2003 | 03:29 PM
hondachick81's Avatar
Default Squeaky Suspension...Spray Lube??
My back sway bar is squeaking alot on bumps and turning....its a little annoying, and I know its coming from the bushings. Do they make some kind of lube that I can spray on the bushings so that I don't have to take them completey apart to lube the insides. Can I do anything to stop the squeaking without taking apart the sway bar??
thanks
Old Jan 14, 2003 | 03:53 PM
tominos's Avatar
Default Re: Squeaky Suspension...Spray Lube?? (civicgirl114)
wd40
Old Jan 14, 2003 | 04:55 PM
ChiBoy's Avatar
Any kind of spray will be temporary at best. Unfortunately, the longest term solution will be to open it up and put some lube in there. The stuff from Energy Suspension is good stuff. Thick and water resistant. Don't know if you can use it on rubber bushings though.
boxedfox
Suspension & Brakes
Apr 22, 2018 10:35 AM
dgerej2
Suspension & Brakes
May 21, 2010 05:55 AM
bopbop93030
Suspension & Brakes
May 19, 2009 04:51 PM
RalliartRsX
Suspension & Brakes
Nov 21, 2005 04:50 PM
