how to check if distributor is good?
Old Jan 14, 2003 | 09:37 AM
serious's Avatar
Default how to check if distributor is good?
i have a distributor on an engine that's out of the car. is there anyway i can check if the distributor is good before i swap the engine in? it's a z6.
Old Jan 14, 2003 | 10:00 AM
4drEF's Avatar
Keyboard Humorist
Default Re: how to check if distributor is good? (serious)
What ECU are you going to use? I hope a P28 that matches the Z6 distributor you are toying with. You can't mix and match and OBD1 dizzy to a OBD0 ECU.
You should look into the 5g forums. Maybe somebody over there can scan the HELMS instructions for testing the sensors in the dizzy.
Old Jan 14, 2003 | 10:50 AM
serious's Avatar
Default Re: how to check if distributor is good? (4drEF)
yeah, it's a p28.
Randysi
49
Oct 30, 2011 09:54 PM
88EDHatch
Dec 3, 2010 10:02 AM
PhatHatch89
Jun 13, 2003 12:07 PM
vtecrx
Nov 8, 2002 05:18 PM
