Crx ecu problem...
Well my cousin has a '90 crx si and his check engine light is on, so we locate his ecu and it has a red led that blinks 9 times. Is this led suppost to blink or is it the code for the cel it threw? Any help is appreciated thanx.
CYP Sensor (Cylinder)
defective circuit or unplugged / defective sensor
http://tech.hybridgarage.com/tech/codes.html
[Modified by altoid, 11:00 AM 1/14/2003]
Yeah the LED will flash. Code 9 is the Cylinder position sensor in the Distributor. B4 I would get a new distributer I would reset the ECU by pulling the hazard and ECU fuses for about 15 seconds and replace them then drive it around to see if it does it again
[Modified by zCivic, 11:02 AM 1/14/2003]
ExplicitSnow
10
May 19, 2005 04:38 AM
