disconnecting VAFC for REF
Anyone know if I can disconnect the VAFC unit from the signal harness, rather than from the ECU, for a smog test. Will the car still start if the VAFC is disconnected from the signal harness?
Thanks.
Thanks.
why would you want to disconnnect it for a smog test? Seems like leaning things out and stuffing it in the glove box would be a better option.
I supose I could do that, I'd still have to disconnect and re run the wire. I just want to know if it would still work, so I could just disconnect it right before the test then connect it right after. Plus it is stuck onto my ash try, and i'd have to re stick it afterwards.
[Modified by DOSPOWND, 1:43 PM 1/14/2003]
You have to jump the two MAP wires and the two VTEC wires with a small paper clip or something. Be carefull, you can bend the pins inside your connector very easily and then you'll need a new harness. Don't ask how I know....
IgniteTeg
May 1, 2002 03:57 AM
