What shocks for straight out comfort?
Old Jan 13, 2003 | 11:40 PM
cracker099's Avatar
Default What shocks for straight out comfort?
I have Neuspeed sport springs,which have a pretty low spring rate(250f and 185r). What shocks would you recomend for a comfort/luxury only ride? I will never auto-X and I never street race. If you could list your primary and secondary choices that would be great. thanks
Old Jan 14, 2003 | 01:04 AM
turbohonda's Avatar
Default Re: What shocks for straight out comfort? (cracker099)
I would say for value and ride the Tokico blues.
Old Jan 14, 2003 | 01:10 AM
216.226.142.95:27016's Avatar
although the spring rates are not that much diffrent from stock, the drop is. i recomend getting some afterket shocks like koni reds (spring rates are not that drastic to use yellows), tokiko, or any aftermarket shocks for sale.
Old Jan 14, 2003 | 04:09 AM
ebelp's Avatar
Default Re: What shocks for straight out comfort? (216.226.142.95:27016)
KYB GR2's.
Old Jan 14, 2003 | 04:42 AM
drewspeed's Avatar
Default Re: What shocks for straight out comfort? (ebelp)
KYB GR2's.
Old Jan 14, 2003 | 09:30 AM
cracker099's Avatar
I forgot to mention that I already have KYB GR2's and they are stiff for me. Either that or it's starting to weaken already? I heard the Tokico Blues and GR2's are on the same level. Does that mean the Blues are just as stiff?
Old Jan 14, 2003 | 09:43 AM
Jesse H's Avatar
AGX or Illuminas on full soft.
Old Jan 14, 2003 | 09:55 AM
jeebusm3's Avatar
Default Re: What shocks for straight out comfort? (Jesse H)
If you want comfort you probably don't want a teg. Stock they aren't that great.
Old Jan 14, 2003 | 10:05 AM
96IntegraLS4DR's Avatar
Default Re: What shocks for straight out comfort? (drewspeed)
KYB GR2's.
My vote to GR2.
Old Jan 14, 2003 | 10:06 AM
cracker099's Avatar
Default Re: What shocks for straight out comfort? (gtravsr)
True true, but I gotta live with what I have. So I've pretty much narrow my choices down to the Koni reds and Tokico Blues. I can get either of them for almost the same price. Decisions decisions....
Old Jan 14, 2003 | 10:13 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
comfort and lowering springs do not go together... sorry but that's just the way it is. Of course comfort is a relative term, but if you mean big car soft ride or even stock Integra/Civic ride, it's just not gonna happen if you have lowering springs.
Old Jan 14, 2003 | 10:45 AM
mickey513's Avatar
Kyb Gr2
Old Jan 14, 2003 | 10:57 AM
Tweakmeister's Avatar
Default Re: What shocks for straight out comfort? (mickey513)
stock (everything) hah.
I'd say Bilstein SP but you'd have to replace your rear lca's.
KYB's or whatever...
[Modified by Tweakmeister, 3:01 PM 1/14/2003]
Old Jan 14, 2003 | 11:26 AM
IntEGNYC's Avatar
Default Re: What shocks for straight out comfort? (turbohonda)
FOr value, slight lowering and ride Tokicos.
KYB's and illuminas are must more pricier and are a bit stiffer.
Old Jan 14, 2003 | 11:30 AM
nine6's Avatar
I have the KYB AGX with Eibach Sportlines. I'd say better than stock.
Old Jan 14, 2003 | 11:34 AM
cracker099's Avatar
Default Re: What shocks for straight out comfort? (Tweakmeister)
Yea, I was contemplating the Blistiens too but they only make the Heavy Duty for ls/rs/gsr and I've heard they weren't made to go with lowering springs. The Sports on the other hand can handle the lowering but only the damn lucky Type R's get them
Old Jan 14, 2003 | 11:47 AM
daLixz25's Avatar
Default Re: What shocks for straight out comfort? (nine6)
I'm looking to go with this combo. How does it ride/corner/handle?
Old Jan 14, 2003 | 11:53 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: What shocks for straight out comfort? (daLixz25)
I am also doing the same set-up. Right now I just have the springs and the ride is ok but I need a camber kit and my stock shocks are dying. I never drove it with stock springs but I think it handles pretty good.
Old Jan 14, 2003 | 12:16 PM
nine6's Avatar
Default Re: What shocks for straight out comfort? (arizsun21)
Like I told arizsun21, a camber kit wasn't needed as per the alignment shop, while rolling with 17's. but when I have my 14" hubs installed (for the heck of it and try to look like a wannabe JDM tuner) the shop recommended a camber kit or change my springs so it wont drop lower. I will be installing my stock 2000 GS-R rims and we'll see if the camber cannot be corrected by factory setting and if camber kit is needed.
as per the ride, I love it better than stock. I havent used any other aftermarket shocks so I cannot compare it. I know while riding stock shocks, when I hit the lil metal reflector that divides the lanes on the freeway, I hear this "THUD" and really hard bump. After installing the AGX, whoa, smooth like a motha as always, you can change the settings to make it stiffer. hope this helps...
Old Jan 14, 2003 | 12:53 PM
tilt's Avatar
Get rid of the neuspeeds if you want comfort. Also the rear springs/shocks affect comfort moreso than the fronts... keep that in mind. Seems kind of pointless to drop a car for looks, but whatever floats your boat.
Old Jan 14, 2003 | 02:04 PM
XDEep's Avatar
Default Re: What shocks for straight out comfort? (tilt)
uh you mean the fronts have more of an impact. i would get agx as they are relatively cheap and you can choose which setting you like. i adjust mine all the time. have them on eibach sportlines too, also very soft. if youre strapped for cash, just get teh fronts for now, and gr2's for the rear later. rears arent nearly as important as fronts
btw, are you on stock tires or low pro's? most low pro tires are very stiff. i bet getting soft tires will make the biggest difference. i had to ride on my stock alloys for a while and they were tremendously softer. they are yokohama avid 195/60/14. i missed the traction and handling so i went back to my falken 205/50/15's. so much stiffer and you can feel every bump but oh well
Old Jan 14, 2003 | 08:21 PM
jeebusm3's Avatar
Default Re: What shocks for straight out comfort? (XDEep)
After reading this thread I decided to lower the stiffness on my AGX just to see what it was like. I normally run 3f, 4r on them and it is damn stiff, and turns quickly, doesn't understeer much, and hardly rolls. So for the first time I set the fronts to 1 today and the back to 2 (I like the back harder than the front to rid understeer) and it was pretty comfortable. I was surprised. It wasn't as fun as before but a lot less painful. This is on GC's with "I think" 350f, 280r rates.
Old Jan 14, 2003 | 08:31 PM
SilverDc2's Avatar
i have a weird setup. i have AGXs in the front and tokico blues in the back. i would have to say go with AGXs because their adjustable. they also run for 400. tokicos blues are go but you might blow them because when i bought mine it said "recommended drop is 1.5 in max" i have a 1.75-2.0 since i coilovers i can't tell its still firm though. the price on some tokico blue are 250 at the shop i go to.
plamauski
Dec 21, 2004 06:24 AM
Toretto
Feb 18, 2004 06:40 PM
shattergsr
Sep 12, 2002 05:39 PM
myst179
Apr 16, 2002 07:09 PM
Seedc2
Oct 29, 2001 12:22 AM
