another damn jdm headlight question...
Old Jan 13, 2003 | 09:12 PM
zer0zer0 TypeR's Avatar
Default another damn jdm headlight question...
for those of you have the jdm conversion WITH factory HID, how did you mount the ballast on the driver side? i bent the ac lines out of the no problem, but than now the washer fluid bottle is in the way. did you just unbolt it and push it back? help a brother here!
Old Jan 13, 2003 | 09:13 PM
B2FiNiTY's Avatar
Default Re: another damn jdm headlight question... (zer0zer0 TypeR)
You mean the passenger side right?
Old Jan 13, 2003 | 09:15 PM
Default Re: another damn jdm headlight question... (B2FiNiTY)
uhh last time i checked the washer fluid bottle is on the driver side. And quit posting before i call yo momma! j/p
Old Jan 13, 2003 | 09:20 PM
DarthLuder's Avatar
New User
You should of got the non hid than you wont have this problem.
Old Jan 13, 2003 | 09:21 PM
B2FiNiTY's Avatar
Oh yeah. I was thinking radiator overflow bottle.
Old Jan 14, 2003 | 07:19 AM
itr449's Avatar
This is what I did. While the fender and everything is off. Just unbolt the bottle from the side where it's anchored into the car. Then just push on it til it moves back to where you want it. Then just bolt the headlight in. The bottle won't go anywhere. It might sound kinda like a "hack" thing to do but it worked for me. My friend and I did it ourselves using Mase's post about a month ago
Old Jan 14, 2003 | 07:30 AM
yoshi234's Avatar
I shoot brides
call up steve at passwordjdm (he may be in japan ri now) and get a jdm washer bottle
yshi - who picked up one couple weeks ago
Old Jan 14, 2003 | 07:34 PM
ITR#132's Avatar
Default Re: another damn jdm headlight question... (yoshi234)
Thats what I got on mines. Looks kind of weird when you firs put it in though.
Old Jan 14, 2003 | 10:10 PM
GoldenONE's Avatar
i dont know if u wanna do this but i mounted mine behind the fenders and just got some wires at radioshack to to connect them
Old Jan 14, 2003 | 10:11 PM
Type R's Avatar
Default Re: another damn jdm headlight question... (itr449)
thats what i did
[Modified by Type R, 11:13 PM 1/14/2003]
Old Jan 14, 2003 | 10:35 PM
Mike M's Avatar
Founding Member
Default Re: another damn jdm headlight question... (Type R)
Geez guys use a little ingenuity
Get these tools:
Heat Gun
Permenant Marker
Piece of Angle Iron a couple of inches long
Some Heat resistant Gloves
Make a mark on the Bottle for where the Bottom of the ballast would be and another for aprximately how far back the ballast has to go (add about 1/8th-1/4 of an inch more just in case you need the space)
Take the bottle out, Slowly Heat up the section with the heat gun until the plastic is somewhat soft, Wearing your gloves take the 90degree Angle iron and form the soft plastic so that the ballast will fit, you may need to reheat the plastic a few times to get the perfect L Shape bent into it.
Old Jan 20, 2003 | 02:34 PM
passwordjdm's Avatar
Default Re: another damn jdm headlight question... (Mike M)
Get these tools:
Heat Gun
Permenant Marker
mikey, u so smart!!!! ... thats exactly what i did when i installed an HID frnt about a year ago. you'd be surprise how many people would think that this is beyond their capabilities... not so mechanically inclined i guess.
to simplify things... i just throw it in with my HID purchases if i have any.
kliq
Jun 5, 2003 07:03 PM
zer0zer0 TypeR
Feb 13, 2003 05:59 PM
