Brembo rotor install?
Old Jan 13, 2003 | 08:57 PM
jdm169's Avatar
Default Brembo rotor install?
I can just but new Brembo rotors for my 91 crx si correct without buying a whole kit? any others do this? worth it? is the installation easy? Also is the rotor larger in diameter than the stocks? thanks for all your help so for so much questions hopefully all will be answered thanks
Old Jan 13, 2003 | 09:02 PM
jdm169's Avatar
Default Re: Brembo rotor install? (jdm169)
Old Jan 13, 2003 | 09:33 PM
EG8R's Avatar
You have to get stock sized rotors.... The only way to go bigger is get a kit or other parts to accept the rotors
Old Jan 13, 2003 | 11:08 PM
jdm169's Avatar
Default Re: Brembo rotor install? (mr. skelly)
Does Brembo make stock sized rotors? And if so, are they any better than stock?
Old Jan 16, 2003 | 12:53 AM
travis's Avatar
Yup. The blanks are cast iron just like OEM, and I wouldn't really say they're better or worse. They're just a good replacement for old rotors. Direct bolt-in.
Old Jan 16, 2003 | 08:51 AM
joshwhe's Avatar
just put mine on with aem pads yesterday they feel alot better then stock.... i like em much.
Old Jan 16, 2003 | 08:54 AM
Ef Whore's Avatar
Default Re: Brembo rotor install? (joshwhe)
by the end of the week they will grab like a ****---if u bedded them in properly....
AndThenYouSay
51
May 21, 2011 04:01 AM
oh-k
Aug 22, 2004 08:31 AM
Integraoligist
Jun 24, 2004 05:37 PM
YelloEco
Jun 8, 2004 06:30 PM
Alexander
Oct 5, 2002 12:25 PM
