Introducing CEL 67 With a Suprise Appearance From ABS Code 16
Old Jan 13, 2003 | 07:52 PM
CPR's Avatar
CPR
Default Introducing CEL 67 With a Suprise Appearance From ABS Code 16
CEL came on while driving home and I confirmed that it was code 67. I have a P28 that can fix that issue so I'm not frettin over it. The weird thing is, when I was checking the CEL code, the ABS light started dancing too and it gave me a code 16 which, according to the Helms, is Right-rear wheel sensor (electrical noise/intermittent interuption). I'm going to check the sensor tomorrow but I'm not really sure what I'm looking for. The weird thing is, when I'm not shorting out the connector and I turn the ignition in the ON position, the ABS light doesn't even light up. What's your take?
Old Jan 13, 2003 | 07:54 PM
baonest1's Avatar
Default Re: Introducing CEL 67 With a Suprise Appearance From ABS Code 16 (CPR)
lol.. i like the title. i didnt bother reading your post.. lemme go back and read it.
Old Jan 13, 2003 | 07:55 PM
baonest1's Avatar
Default Re: Introducing CEL 67 With a Suprise Appearance From ABS Code 16 (baonest)
is the ABS comp in good shape..
i beleive mine is bad and the light is on once in a while.. most of the time it stays on. but i dont really mind. ive been ABSless for a long time now
[Modified by baonest, 11:56 PM 1/13/2003]
Old Jan 13, 2003 | 08:01 PM
vtec.dc2's Avatar
this is normal, i noticed the same thing.. and i think its on every teg out there.. you should only read for cel light flashing - abs will flash code 16 - which is not to mean anything.
Old Jan 13, 2003 | 08:03 PM
io_burn's Avatar
New User
Default Re: Introducing CEL 67 With a Suprise Appearance From ABS Code 16 (vtec.dc2)
I have no input on the matter other than this is the best topic title I've seen this week... lol
Old Jan 13, 2003 | 08:08 PM
baonest1's Avatar
Default Re: Introducing CEL 67 With a Suprise Appearance From ABS Code 16 (io_burn)
its only monday night
Old Jan 13, 2003 | 10:05 PM
sgT's Avatar
sgT
abs always shows some sort of code.
either pulser or sensor. no worries, its nothing
Old Jan 14, 2003 | 06:57 AM
CPR's Avatar
CPR
Default Re: Introducing CEL 67 With a Suprise Appearance From ABS Code 16 (sgT)
Thanks...it seems like it's getting harder to get tech questions answered in this forum so I had to come up with a catchy title.
Thanks for the info! I guess the only time I need to worry about any sort of ABS code is when it actually comes on while driving, right? I reset my ECU this morning and the CEL 67 hasn't come back after a 30 minute drive. I'm hoping that the code appeared only because I've been driving like a granny due to clutch break-in and the cat was not heated enough to be effective.
Old Jan 14, 2003 | 07:15 AM
andrewasf77's Avatar
on the abs code, i have the same thing. my abs flashes a code 16 whenever i jump my ecu to check a cel code. i think this is normal, as my abs has no problems.
Teamdiesel
Dec 11, 2007 01:12 AM
quazar
Jul 13, 2004 06:53 PM
roadawg
Mar 5, 2003 03:37 PM
andrewasf77
Nov 26, 2002 09:19 AM
