gsr ecu?
Old Jan 13, 2003 | 05:03 PM
RotiEatter's Avatar
Ditto
Default gsr ecu?
Can anyone explain to me how the GSR ECU works with the H22A?
also, is it plug and play?
also, will it work with both USDM and JDM H22A?
Old Jan 13, 2003 | 05:16 PM
satan_srv's Avatar
Default Re: gsr ecu? (RotiEatter)
They have basically the same ecu pinouts OBDI to OBDI so they do the same thing.
https://honda-tech.com/zerothread?id=383036
I don't recommend it unless you have V-AFC at the minimum
[Modified by satan_srv, 9:21 PM 1/13/2003]
Old Jan 13, 2003 | 05:22 PM
RotiEatter's Avatar
Ditto
Default Re: gsr ecu? (satan_srv)
Thank you.
Old Jan 13, 2003 | 05:30 PM
RotiEatter's Avatar
Ditto
Okay, I read what you posted..
What's ATTS? I have a 92 Civic.
I want to put a JDM H22A with LSD in it
and I was curious about the GSR ECU, I will run a Apexi V-FAC and other fuel enhancements, etc.
I do also plan on getting the car dyno tuned, or atleast dyno tested
Also, do you happen to know if this works well with a H22A4 with a Turbo?
My brother has a 97 Accord with a USDM H22A4. He would like to go turbo, and I didn't know if the ecu would matter...I don't think he plans on running a standalone engine mangement
Old Jan 13, 2003 | 05:47 PM
satan_srv's Avatar
Sorry the ATTS only relates to the Type-SH, and the sensor is only for the OBDII ecus...
GS-R + V-AFC is okay but you have to dyno tune to get the right VTEC point and fuel becuase you will be lean. Have to have a wideband O2 readout.
As for turbo...a GS-R ecu with an OBDI swap and a Hondata would be good. But if he's not getting a standalone he doesn't really gain anything over a stock ecu, except for an OBDI conversion.
Ty.jon
Oct 8, 2018 08:20 PM
will@strd
Jan 13, 2006 06:48 AM
snake679
May 15, 2003 04:27 AM
se93
Oct 19, 2001 04:51 AM
