91 crx si with zc and 88si tranny/ what clutch/flywheel and what axles?
88si cluth and fly..
some companies sell a kit and you can use the 88 tranny with an upgrade option which will let you use a bigger clutch..
But for the easy way out just get a 88si set up... its all based on your tranny and the number of splines.
As for the Axles, do you have the intermediate shaft..
if not you can use your old axles.
use your 88 flywheel and clutch set-up and stock axles will work, your just changing the motor man
[Modified by SIRX, 4:55 PM 1/13/2003]
get a 86-89 accord 2.0 disc, 90-91crx si pp and flywheel and you will be able to run the 212mm setup instead ofthe stock 200mm, this is what im runing and what i have been runing for over 2yrs and works great..
the 88 tranny has 21 splines on the input shaft and the 89up has 20 spline, the 88 clutch was 200 mm hte 89 was either 200mm or 210mm ( i forgot) and 90-91 is 212mm.
Gant
15
Feb 17, 2004 03:01 PM
It's*BOLO!!
May 10, 2003 05:24 AM
