Accord/TL rear-sway-bar swap?
I noticed that Comptech's swaybar set for the 1999 Accord is the same part number as the TL's. I was wondering if anyone has swapped out a TL Type S rear swaybar for an Accord's. The Acura bar is 19 mm vs. 16 mm for the Accord.
Could you use the existing Accord ends links and other hardware? I know that you have to get the Acura bushings and clamps to attach to the frame.
Thanks,
Rimmer1
Thanks,
Rimmer1
i purchased the cl-s sway for my coupe and the bolts as well.
i ordered the poly bushings from neuspeed (19mm) and they came with the brackets. thats all u need. u cant use the poly with the cl brackets u gotta have the neuspeed ones.
-cb
-cb
not trying to jack your thread but how much did all the supplies cost and do you have a list of the parts that is needed? thanks
For Acura Parts from Acuraautomotiveparts.com you need:
Swaybar (35899) $30.89
The bushings and clamps are listed for a 18mm bar (which is either the wrong part number or wrong size but since they're so cheap it doesn't matter -- i.e., make sure its for a 19mm bar
Bushing (35946) $2.82 x 2
Holder (35970) $3.45 x2
And then 4 bolts .55 each.
I will be getting the pricing on the Neuspeed poly bushings and clamps later, but they will be in Canadian dollars.
Techno Tonis
Jan 21, 2010 04:54 AM
First Honda 1976
Apr 14, 2004 02:04 PM
